Sqeeking!!!!
Old Jan 21, 2005 | 07:57 PM
therckid's Avatar
Car: 1986 Trans Am
Engine: 305 LB9 TPI
Transmission: 700-R4
Sqeeking!!!!
Ok this is sorta funny. yet really simple.
While i drive the brakes sqeek, when i apply pressure the sqeak stops completely. ITs thew drivers side front brake. Its getting relaly annoying and it just started today.
People keep saying its a loose brake pad. How can i fix it? Can it just be re installed or what?
Thanks,
Shane
Old Jan 21, 2005 | 08:00 PM
slowTA's Avatar
Car: '88 Formula
Transmission: T-5... in need of slight rebuild
Sounds like the wear indicator on the pads. Take a look in there and see how much pad thickness you have left. I'm betting you'll have to replace them soon.
Old Jan 21, 2005 | 09:06 PM
therckid's Avatar
Car: 1986 Trans Am
Engine: 305 LB9 TPI
nah the pads and calipers are less then a year old, less then 10k miles old. They are not bad. I might be bad on tires, but i'm not too bad on brakes.... And the difference is the wear indicator squeeks while force is applied, mine doesn't, it squeeks when there is no force.
Old Jan 21, 2005 | 09:10 PM
slowTA's Avatar
Car: '88 Formula
Thats not what mine do... when they're worn they squeek while there is no brake pressure, then they stop when I touch the brakes.
I've also done brakes on a friends truck, almost 1 year later the pads were shot. Sometimes the last, sometimes they don't.
Old Jan 21, 2005 | 10:00 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Just go out and spend a few extra dollars on a good set of brake pads and change them. For someone who has just won an award at school in the "Automotive Technician" catagory.
https://www.thirdgen.org/techbb2/sho...hreadid=275794
You should know this information already and not have to post here asking about it. While you are at it, use some of that prize money to replace the rotors,caliphers, wheel bearings, & brake hoses as well. Also use $36.95 of that money to buy yourself a service manual from WWW.HELMINC.COM .
Old Jan 21, 2005 | 10:21 PM
slowTA's Avatar
Car: '88 Formula
Another master mechanic we got running around these boards. I bet the job that said "$200 a week an just come in when we need you" will have him working 60+ hours a week. But it will be OK because, 'he's getting paid to work on cars.'
I don't mend helping people out who have questions, but enough of these know it alls already!!
Old Jan 21, 2005 | 10:55 PM
bulletboy29's Avatar
Car: '87 Camaro SC
Engine: 305 LG4
You beat me to it!
Old Jan 21, 2005 | 11:53 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Axle/Gears: BW, 3.27
Rotor run out or loose spring clip on brake pad are two things you can look at first before spending money.Also check the castle nut on the wheel bearings for looseness.
Old Jan 22, 2005 | 02:31 AM
Joez88Camaro's Avatar
Car: 1988 Camaro Sport Coupe Convertible
Engine: Your Momma
Transmission: I can go forwards and backwards
you guy should just start all out flaming him, I really am wondering whether or not the mods would mind.
Old Jan 22, 2005 | 10:31 AM
The Red86Z's Avatar
Car: 86 Z28/91 dodge stealth rt TT
are you F**cking serious?? yes you probably need new pads, you ask a question someone answers it and you say "no, thats not it" then why do you even ask..... and YOU won an award for auto tech?? I think you need to get a life and quit posting on here. I have almost no posts on here why? Because I answer almost every question i have with a.... you guessed it a SEARCH!!! you have almost 3000 because you will come on here and ask things like this. but i'll have to admit sometimes ill come on here search for your username and im GAURENTEED a good laugh somedays.... but still GET LOST
Old Jan 22, 2005 | 01:27 PM
therckid's Avatar
Car: 1986 Trans Am
Engine: 305 LB9 TPI
well napa cvered it under the warentee in the poroducts i bought. they replaced the entire loaded caliper. So problem is fixed now. Gosh guys , chill out.
Old Jan 22, 2005 | 01:30 PM
slowTA's Avatar
Car: '88 Formula
They replaced it because what part was worn out?
Old Jan 22, 2005 | 02:06 PM
therckid's Avatar
Car: 1986 Trans Am
Engine: 305 LB9 TPI
what ahppened was the brake pad was on slanted, so one side was hitting the pad first, th side with eh wear bar, and it was constantly htiing the rotor. When pressure was applied it straightened out and stopped sqeeking, this is in effect due to faulty parts.
I had a certified Master Tech install the brakes so they had to honor the warentee.
Old Jan 22, 2005 | 09:40 PM
REALPOWER's Avatar
Car: 1984 Camaro on steroids/ 1987 iroc-z28 5 speed.
Engine: 383 nitrous motor / poindexter 305
Transmission: Th350
Damn, the other thread got locked too quick.
TX-SleeperC5
Mar 19, 2013 01:38 AM
1989TransAm
Jun 18, 2004 11:49 AM
speedfreaker
Apr 4, 2002 02:52 PM
