4th gen rear disc rotors
Old Mar 20, 2005 | 12:19 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
Axle/Gears: Stock IRS
i read somewhere not long ago that 4th gen rear rotors will bolt up to my 89 camaro without a problem, thing is, they are different part numbers, and they visually look different. but will that not be a problem?
Old Mar 21, 2005 | 12:43 PM
884+3's Avatar
Car: 88 irocz
Engine: b2l 350
Transmission: corvette 4+3
The rotors should slide right over the studs without any problems. The calipers are going to be your main problem. The rotors are larger diameter which means your going to have to design and build your own caliper mounts.
Old Mar 21, 2005 | 03:07 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
i heard its a direct swap with my pbr rear brakes.
Old Mar 21, 2005 | 04:13 PM
HalfInchWrench's Avatar
Car: 85Z28 87GTA 91GTA 98SS
Engine: SBC, LS-x
Transmission: T-5, 700-R4, T-56
Why don't you take out the two caliper bolts, pull it out of the way and see if it fits then? I highly doubt it will without fabbing up some brackets or buying aftermarket ones.
Old Mar 21, 2005 | 04:15 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
cuz i havnt bought it yet.
Old Mar 21, 2005 | 04:36 PM
Engine: SBC, LS-x
I wouldn't buy it then unless you get some solid comfirmaton. I've done brake conversions but not the one you are trying. I didn't know you didn't have the parts on hand. Didn't mention it in your OP. I assumed you did.
Should have said you plan on buying X for Y price. Can it work and is it worth it AND is it better than what you have now. Might have got more bites.
Old Mar 24, 2005 | 12:10 AM
DuronClocker's Avatar
Car: 1997 Corvette
Axle/Gears: 2.73 IRS
They'll fit, and they should work just fine as well. Someone just asked this question a few days ago and Ed answered with some information. I'm pretty sure its just a direct swap, or at least very close.
Old Mar 24, 2005 | 09:14 AM
Jon92TA's Avatar
Car: 92 Trans Am - Sold
Sometimes an easy solution to 'will it fit' questions like this is to find a local parts store that has both in stock and have them put both on the counter side by side. Should be easy to see if they'll work, you don't have to get dirty and they're right there if you want to buy them.
Old Mar 24, 2005 | 01:23 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
your talking about an auto parts store that caries rear discs for our age camaros in stock? hehe.
Old Mar 26, 2005 | 08:44 PM
zombie-z's Avatar
Car: 1998 ss
Engine: ls1
Transmission: t56
I work at a national parts retailer and went through putting the rotors side by side. The difference is very small as long as you are comparing the pbr set-up to 93+ fbody. The rotor for pbr set-up has more finish machine work done to it. Basically the hat section is fully machined where as 93+ are left rough. There is a different shape to the hats. pbr is machined flat as the 93+ are round. The difference in hat height and overall diameter is very small. The pbr rotors are getting difficult to find and are nearly twice as expensive while the 93+ are common and cheap. I have been running them on my 9bolt for several months now. Ive only recently knocked the crosshatch off the rotors by switching to a 4disc proportioning valve.
Old Mar 26, 2005 | 09:02 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
cool thanks for the confirmation, i know which rotors to buy now.
Old Mar 27, 2005 | 01:09 AM
Justins86bird's Avatar
Car: 86 LG4 & 92 TBI Firebird
Engine: The Mighty 305!
Keep in mind 98-03 rotors are way different then 93-97 rotors.
Old Mar 28, 2005 | 07:41 PM
shr00m's Avatar
Car: 1992 Jade Green---Trans Am Converti
Hmm.. I just finished up my 4th gen rear repaint and purchased new discs for it, 93 TA was the parts purchased. The original rotors look like the rounded 4th gen one's you described.
The new 4th gen one's look like the flat hat 3rd gen one's you described.
These were in stock at O'reilley's for a 4th gen. So looks like manufacturers are either/or and the 3rd gen ones aren't hard to find.
Here's the new "4th gen" rotor..
Kevin D.
Attached Thumbnails 4th gen rear disc rotors-c-documents-settings-kevin
1992rs/ss
Jan 31, 2025 05:10 PM
Vintageracer
Jan 10, 2020 05:33 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
1992rs/ss
16
Jan 28, 2016 09:58 PM
THABADGUY
Brakes
Aug 11, 2015 03:43 AM
