drum to pbr porportioning valve?
Car: 89' RS
Engine: 5.0
Transmission: slipping 700r4, soon probuilt
I have a 89 with rear drums. i replaced the rear with a 89 pbr 9 bolt was wondering if it absolutely nessisary to replace the porpotioning valve?
Car: 86 T/A
Engine: HSR 355
Axle/Gears: 2.77 posi
You can just do the upgrade which is basically removing the valve and whatnot and put a screw in its place. I'd double check to make sure since I'm not very knowledgable on brakes.
Car: 88' Iroc-Z
Engine: LQ9
drum brakes don't take as much pressure to lock up as disk brakes do. So you could do the "bolt mod" as suggested. I did and added a wilwood proportioning valve in line so that i can adjust pressure.
Car: 92 Rally
I just swapped from drum to disc and haven't gotten around to changing my valve yet, and honestly don't know if i ever will.. the car stops wonderfully without changing it. Maybe if I get real bored I'll swap it
Anyone considering this upgrade, I highly recommend it, makes your car look tuff!!!
Anyone considering this upgrade, I highly recommend it, makes your car look tuff!!! Member
From: In my own little world - but they know me well in here
Car: 88 Sport convertible
Engine: 305TBI
Transmission: AUTO
Axle/Gears: 3.42 rear end
did you have any issues with the parking brake cable? Did it fit the disc setup or was any modification necessary? Also, did the brake lines attach OK.
Doing an '88 rear drum swap to 91 rear disc.
Engine: 305TBI
Transmission: AUTO
what i meant (and I guess I should have said to begin with)
The brake lines were all the correct length, pointing the right direction, the emergency brake cable just attached without problems, etc.....
Car: 89' RS
Engine: 5.0
yes everything hooked up right. I dont know bout the ebrake cables i believe that they woulda worked i just never hooked them up cuz i broke those clips
Car: Base Firebird
Engine: TPI 350
Axle/Gears: D44
I did a drum-disk rear end swap, and I chose to swap the proportioning valve since it all came from a parts car. to answer your question, I dont think it would be a problem if you used your drum prop valve... your brakes will still function fine, but I'd assume that you won't be getting the full benefit from the upgrade.
Car: 92 Rally
I had to swap the whole e-brake setup for one that came stock on a disc car. I got lucky on the brake lines, they fit perfectly. However, Chevy did have some variations on the fittings, not all of them have the same thread pitch. Be sure to check that before you start wrenching down on it. Last edited by USA_Rally; Apr 13, 2005 at 01:08 AM.
355tpipickup
Sep 13, 2015 11:35 PM
