1LE Problem
Old Apr 18, 2005 | 06:23 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
1LE Problem
I noticed yesterday that the adapter to spindle bolt head(s) are rubbing on the inside of the driver's side rotor--enough so that spinning the rotor by hand is difficult. The rotor moved freely, however, when I removed the caliper. I cleaned and relubed and the situation improved considerably, but there is still a slight drag. I heard nothing when the rotor spun freely and there didn't seem to be excessive play. WTF?
JamesC
Old Apr 18, 2005 | 02:14 PM
ebmiller88's Avatar
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
Are they GM bolts? Just curious. I'd take a file or grind a small bit off the bolt head to get the clearance, ought to do it.
Ed
Old Apr 18, 2005 | 02:36 PM
JamesC's Avatar
Hey, Ed,
These bolts were a part of Spohn's 1LE kit. You're correct about clearance--wouldn't take much.
JamesC
Old Apr 18, 2005 | 09:39 PM
ebmiller88's Avatar
Can you slide a thicker washer under the bolt head? That would raise it a bit. I'm not sure which bolts he supplies.
Ed
Old Apr 19, 2005 | 06:53 AM
JamesC's Avatar
Wouldn't I need a thinner washer to get the bolt head away from the rotor? Or is it that "darn beer" again?
JamesC
Old Apr 19, 2005 | 06:11 PM
ebmiller88's Avatar
You are right, I was thinking in the other direction. I'd just take a flat file and try to smooth it up a bit or try the thinner washer approach.
Ed
Old Apr 19, 2005 | 06:36 PM
JamesC's Avatar
I knocked the bolt head down some, but the problem remains: Without the caliper in place there is no interference; stick the caliper on and the rotor comes in contact with the bolt head. Warped rotor?
JamesC
Old Apr 19, 2005 | 07:00 PM
ebmiller88's Avatar
If the rotors moving around that tells me the bearings are loose, that shouldn't be happening.
Ed
Old Apr 19, 2005 | 08:29 PM
JamesC's Avatar
With the car up, I tried rocking the wheel back and forth to check bearing play. Nothing noticeable. I'm stumped.
JamesC
Old Apr 21, 2005 | 06:51 AM
JamesC's Avatar
Long story short. I didn't knock enough off the bolt head .
JamesC
Old Apr 26, 2005 | 11:12 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Axle/Gears: BW, 3.27
take a little material off the rotor too.So you dont have to remove too much off the bolt head.
Old May 5, 2005 | 08:39 PM
Parrydise7's Avatar
This is one that I learned the hard way. Did a trial fit on one side. Everything was fine. Failed to do a trial fit on the other and had this problem.
pjsparts
Oct 29, 2025 06:39 PM
88rscamar0
Sep 23, 2015 09:08 PM
383cam
Sep 9, 2015 06:01 AM
andy74
Sep 3, 2015 08:41 AM
greenyone
Sep 2, 2015 03:39 PM
