Rear Disk Conversion Kit
Old May 28, 2005 | 09:58 PM
91_5.7_TPI's Avatar
Car: 1991 RS Camaro
Engine: L03 (want LS1)
Transmission: 700R-4 (and T56)
Axle/Gears: 4th Gen 3.23 posi
I have the rear drums stock. Is there any way I can convert them to disk without having to do anything to drastic? I know the factory 4-wheel disk setup was ABS and that would involve computer work to make a replacement such as that work. Is there any bolt on replacements? Thanks.
Old May 28, 2005 | 10:23 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Stock 91 ones (which aren't ABS, and it wouldn't matter if they were) work pretty good. 89-92 are the years actually.
Some modification wouild be required to the rear end itself; I don't really know how much. Easiest thing to do is to locate a 89-92 rear and swap the whole thing.
Old May 29, 2005 | 01:04 PM
91_5.7_TPI's Avatar
Car: 1991 RS Camaro
So I just find a rear end and axle housings with the disk brakes and replace mine with them/ it?
Old May 29, 2005 | 03:03 PM
ebmiller88's Avatar
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
It depends on if you want just the brakes or the whole rearend. If you just want the brakes, a complete rear conversion can be had for around $600-650, from Baer around $800. If you want different gears, then swap rearends.
Ed
Old Jun 1, 2005 | 09:27 PM
91_5.7_TPI's Avatar
Car: 1991 RS Camaro
If I can find a Z-28 or something that has the rear gears I want and disks, then I can replace the whole thing? I thought I could, but wanted to be sure before I tried.
Another related question: can I use 1LE or whatever the performance package is on the fronts for mine. They are slightly larger than the stock RS ones. Thanks.
Old Jun 2, 2005 | 11:33 AM
ebmiller88's Avatar
Yes, any rear from '82-97 will bolt into your car. You may have issues with your e-brake cable mounts but otherwise it's a bolt in. The front brake will work but you'll have to do a few mods to get them to work.
Ed
Old Jun 2, 2005 | 11:37 AM
'Shifter's Avatar
Car: 87 Z-28
Engine: A worn-out 305
Transmission: T-5, until it dies
You'll probably need to play around with a proportioning valve as
well.
Old Jun 14, 2005 | 10:44 AM
91_5.7_TPI's Avatar
Car: 1991 RS Camaro
Good news. I found guy with a 85 Z-28 he wants to sell. I am going to look at it soon. It also has a 350 4-bolt in it. I am going to get the parts from Spohn that I want to replace on my car for the rear end (LCA's, torque arm, etc) and maybe a new set of gears if it is less than a 3.2x. Before I change them out. I think this will make a good parts car.
Bad news. Monday I ran a virus scan. Clean. Wednesday my computer shut down and refused to reboot. So I am guessing that sometime on Tuesday my computer caught a virus... Working on getting that fixed.
Old Jun 14, 2005 | 06:18 PM
ebmiller88's Avatar
So you're looking at getting an '85 disc rear with the "bad" rear calipers, and then looking at having to install the gears you want to have in it. Why not just find a rear with the good PBR rear discs and the ratio you want? A gear install will run you around $250-300 anyway, so why not just buy a whole rear for around $200-250 and be all set?
Just tryign to save you some money here...
Ed
Old Jun 22, 2005 | 02:41 PM
91_5.7_TPI's Avatar
Car: 1991 RS Camaro
What are the PBR disks? Where could I find a good rear end?
Old Jun 22, 2005 | 03:00 PM
ebmiller88's Avatar
Where are you in TN? I'm in SC and have both a 4th gen 3.23 posi disc rear and a 3rd gen 3.42 disc rear, both with PBR brakes for sale. I also have a conversion or two if you just want the brakes.
Ed
Old Jun 23, 2005 | 09:16 PM
91_5.7_TPI's Avatar
Car: 1991 RS Camaro
PM sent, Ed.
Old Jun 25, 2005 | 06:49 PM
91_5.7_TPI's Avatar
Car: 1991 RS Camaro
I sent a PM asking about the price on the rear ends. Just checking to see if you got it. Thanks.
Old Jul 4, 2005 | 03:12 PM
91_5.7_TPI's Avatar
Car: 1991 RS Camaro
I am in northeast TN, south of Bristol. What are you asking for the rears. Thnx
Old Jul 4, 2005 | 03:18 PM
ebmiller88's Avatar
I thought I sent you mail on them? No? I'll send you one now.
Ed
Old Jul 4, 2005 | 03:19 PM
91_5.7_TPI's Avatar
Car: 1991 RS Camaro
I didn't recieve it if you did. Thanks.
Old Jul 4, 2005 | 03:24 PM
ebmiller88's Avatar
Sent..
Ed
hectre13
Dec 11, 2023 08:14 AM
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
MoJoe
Fabrication
Aug 19, 2017 07:12 PM
hectre13
Aug 26, 2015 08:17 AM
