You Know How We Search & Search for Answers, But Never Find The Right Posts?
Old May 30, 2005 | 04:24 PM
NoTransistors's Avatar
Car: '83 Firebird S/E
Engine: The Chevy 305. with carburator
Transmission: 700R-4
1983 'Bird/ Factory rear discs.
I just installed the REAR caliper recall kit.
Light was still lit, so in an attempt to tinker, I cracked the switch screwed into the prop valve. I would like to keep that warning-light feature. So, now, I might as well put in a new or better valve. Am I correct in assuming that it is part # 14089496, and are the lines direct-fit?
P.S.- The more I drive with the rebuilt rears, the harder the pedal gets, and the tighter the emergency-brake lever gets. At least something is right.
Happy Holiday
Seth
Old May 30, 2005 | 09:26 PM
RTFC's Avatar
Car: Agood2.8,
Engine: V6rsr,
Transmission: Afrikingoodtime
No you can't. 1983 is a PRE- Metric car (standard fittings) and that Combo valve is metric.
Sorry I can't help with the correct part number for you on a car that early.
Old May 30, 2005 | 09:33 PM
Thank you. At least I now know that I am not being ignored, and my plumbing is not metric. Perhaps another individual has the appropriate part #.
Seth
18inchboyds's Avatar
Car: 1985 Trans Am
Engine: vee eight
Transmission: auto
Axle/Gears: 4.10 gears
hey i might be able to help , i have an 82 mecham trans am that im gonna scrap , if you need it i can get it off for you and sell it to you , if your interested in it pm me .
Old May 30, 2005 | 09:38 PM
Thank you. Your offer might be the simplest answer. What is a Mecham?
Seth
NoTransistors@aol.com
Old May 30, 2005 | 09:42 PM
Car: 1985 Trans Am
Engine: vee eight
Transmission: auto
a mecham is like an slp firehawk , but back in the 80s, also i just remembered that the car is a 4 wheel disc car too , so thats good for you .
Old May 30, 2005 | 09:45 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
GM P/N 25511944
Old May 30, 2005 | 09:50 PM
GMPartsDirect does not recognize this #. Any thoughts? Thanks.
Seth
Old May 30, 2005 | 09:52 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
I've occasionally found parts that they don't list that are still available, but more likely something that old is NLA.
Old May 30, 2005 | 09:57 PM
Well, then, is it appropriate to accept "18inchboyds' kind offer? Seems to be the right part.
Seth
Old May 30, 2005 | 10:03 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
It sounds like it should be the right one.
Old May 30, 2005 | 10:05 PM
OK, 18inchboyds, lets go for it.
jklein337
Sep 19, 2018 06:23 PM
aaron7
Aug 17, 2016 06:02 PM
Juneb1022
Firebirds Wanted
Oct 12, 2015 08:12 PM
formula_novice
Aug 18, 2015 08:48 PM
THABADGUY
Brakes
Aug 11, 2015 03:43 AM
