Big brake question (Spohn's)
Old Jun 7, 2005 | 09:20 PM
soulbounder's Avatar
Car: 89 TTA
Engine: Turbo 3.8
Transmission: 200R4
I was wondering if the Pro-series 13" Big Brake Kit Spohn sells is DOT approved. I'll end up emailing him tomorrow to ask, but I figure there may be someone that might know tonight.
I remember seeing a matching rear setup (for the 4th gen I think) that maybe RTFC had used. I looked up that kit today at Summit and it was not DOT approved. To me, I think there would be some kind of issue with insurance maybe. Of course, it would easily fall under the don't tell if they don't ask category.
Old Jun 8, 2005 | 11:04 AM
nape's Avatar
Car: American Iron Firebird
Engine: The little 305 that could.
Transmission: Richmond T-10
Axle/Gears: Floater 9" - 3.64 gears
I doubt it is DOT approved. That recognition definately isn't cheap.
Old Jun 8, 2005 | 08:56 PM
ebmiller88's Avatar
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
Ummm...no. Wilwood clearly states on the caliper boxes and in other areas that they are race only calipers. Plus I doubt he's had the brackets and hubs tested for that kind of certification. The brake lines are tho....
Ed
Old Jun 9, 2005 | 03:43 AM
Justins86bird's Avatar
Car: 86 LG4 & 92 TBI Firebird
Engine: The Mighty 305!
I believe to be DOT approved, one req. is that the cailpers need to have dust boots. The Wilwoods do not.
The braided hoses included in the kit are DOT approved.
Old Jun 9, 2005 | 07:14 AM
Car: 89 TTA
Engine: Turbo 3.8
Transmission: 200R4
I see. It is strange that the 4th gen wilwood upgrade kits (front) through Summit list as DOT approved. The calipers do not look that different to me.
Would Spohn's kit be recommended for a daily driver or would the 1LE or similar Baer kit be better for that application? The cost difference between these and the Pro-series is not very much and I have heard the praises of fixed calipers over floating ones so I am just wondering.
Old Jun 9, 2005 | 07:57 PM
Joez88Camaro's Avatar
Car: 1988 Camaro Sport Coupe Convertible
Engine: Your Momma
Transmission: I can go forwards and backwards
Get the 13" C4HD or the C5's. They're 90% as good, a fraction of the price, and the parts are a lot cheaper and easier to get (and the basic components are DOT approved)
Old Jun 10, 2005 | 02:27 AM
RTFC's Avatar
Car: Agood2.8,
Engine: V6rsr,
Transmission: Afrikingoodtime
I can prove in the event of a problem that the kit I bought from Summit was in fact a DOT approved setup- Or at least that was the info protrayed to me when I based my decission purchased it.
WIL-140-7763D $1,411.99
Estimated Ship Date: Today
Application Show All
Brand: Wilwood
Product Line: Wilwood Superlite 6 Big Brake Front Disc Brake Kits
Disc Brake Kit Type: Manual
Front Spindles Included: No
Master Cylinder Included: No
Front Rotor Included: Yes
Front Rotor Thickness: 1.25 in.
Front Rotor Diameter (in): 12.90
Front Rotor Construction: Vented
Front Rotor Style: Cross-drilled/Slotted surface
Minimum Recommended Rim Diameter (in): 17
Front Caliper Included: Yes
Front Caliper Piston Quantity: Six
Front Caliper Finish: Black anodized
Front Caliper Material: Billet aluminum
Brake Lines Included: No
DOT Approved: Yes
Quantity: Sold as a kit.
Old Jun 10, 2005 | 06:53 AM
ebmiller88's Avatar
I forgot to mention that the main reason I doubt that kit is DOT approved is of the hub. I make them and run them on my own car along with a host of others on the site and elsewhere and have full confidence in them, but I doubt the hub would get the OK from DOT.
Ed
Frozer!!!
Jan 19, 2024 04:55 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
redmaroz
Aug 16, 2015 11:40 PM
kyle5647
Aug 15, 2015 11:56 PM
Leggman1
Aug 6, 2015 04:15 AM
