Sticking Fronts! HELP!!
Old Jun 26, 2005 | 12:57 PM
Rayzer999's Avatar
Car: 91 Z28 LS Swapped
Engine: 5.3 Turbo LS
Transmission: T56 Mag
Open post for ideas:
Im having an issue when braking where the fronts lock and stick engaged! After garaging it for the winter, I figured that the calipers were most likely sticking and considering the age, it was due time to replace them.
SO I went ahead and installed new roaters, calipers and pads. While I was at it I of course replaced the wheel bearings, knowing the price was cheep for good performance bearings. However, after finishing I have the same issues!!!!
At this point my gut feeling is that the rubber lines are the issues on the calipers. Any another ideas here before I go out and buy a set of steel braded? $70 is quite a bit to pay for something that is a guesstamate again!!
Note, I do have the 4th gen rear disk mod installed with a proportion valve, but the setup has worked well for over a year with no issues. Ive even tried full and no bias to the rear just to try and rule out any issues with the proportion valve. The rears seem to work fine with no sticking.
HELP!
Old Jun 26, 2005 | 08:34 PM
TheGreatJ's Avatar
Car: 91Z, 91RS, '84 Jimmy
Engine: L98, 355, L98
Transmission: 700R, T56, 700R4
Definitely the hoses. If you get braided lines get them from Earl's. Some of the others are known for coming apart...run a search for more info.
Old Jun 26, 2005 | 08:38 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Steel braided hoses are an upgrade over stock anyway, so it wouldn't be a complete waste if it turns out to not be the brake hoses.
Old Jun 27, 2005 | 07:51 PM
Rayzer999's Avatar
I went ahead with the Earls. Let's hope its the lines!
Anyone know if the 4th gen calipers can accept these third gen Earls?? I suspect no.
Old Jun 28, 2005 | 07:20 AM
WaOnFiRe's Avatar
Car: 1988 Pontiac Firebird Formula 350
Engine: 5.7L
Transmission: Automatic 4 speeds
Axle/Gears: 2.77
I had the exact same problem, I changed the 2 front hoses with NAPA ones just to see if it was the problem, and these were the culprits...
Old Jun 28, 2005 | 09:29 AM
Dan8289gta's Avatar
Car: 89 GTA
Engine: 350 tpi
Had same problem also, culprit rubber lines.
Old Jun 28, 2005 | 11:43 AM
Rayzer999's Avatar
Thanks to all of you whom expressed your experiences. It always amazes me to see how many users get active on this board. Thanks to all you who make it a positive experience!
Old Jun 30, 2005 | 01:10 PM
Rayzer999's Avatar
Earl's installed. All I need now is a partner in crime to help bleed them and I will be ready to give another shot.
Old Jul 5, 2005 | 06:50 PM
Rayzer999's Avatar
Problem solved. Earl's solved the problem.
AussiePr0nCar
Mar 6, 2020 04:04 PM
lt1z350
Aug 28, 2015 05:57 AM
Bert87
Aug 23, 2015 03:50 PM
Wife'sCar
Aug 22, 2015 01:46 PM
overdriv
Aug 20, 2015 03:52 PM
