flare wrench
Old Sep 21, 2005 | 08:13 AM
HorseflyDF's Avatar
Car: 86 Camaro Z28
Engine: 350 sbc goodwrench
Transmission: T-5 in the works
Axle/Gears: 10 bolt 3.42 open
flare wrench
Hello brakers,
l have to remove the brake line from the backing
plate 86 camaro drum brakes..
Can someone please tell me what size wrench
I should purchase for that job?
Any other tools I will need I have to swap my brake lines
to another rear end.
Old Sep 21, 2005 | 09:06 AM
Gladstoneiroc's Avatar
Car: 91 Camaro RS
Engine: 5.0L TBI (ebl inside)
Axle/Gears: 3.42 lsd 10 bolt
If you can get one that has a 10mm end and a 12mm end. Then you be able to do almost all brake lines. You need a 10mm though.
Old Sep 21, 2005 | 09:19 AM
HorseflyDF's Avatar
Car: 86 Camaro Z28
cool thanks
Old Sep 22, 2005 | 01:23 PM
Jetmeck's Avatar
Car: '89 GTA 9,000 MILES
Axle/Gears: 3.27 9 bolt
After almost twenty years I seriously doubt the correct wrench mentioned in the above quote will work for you. For sure soak the fittings with some sort of penetrating lubricant five or six times and let it soak overnight, then try the correct size tubing wrench for the line fitting. MORE THAN LIKELY YOU WILL HAVE TO BRAKE IT LOOSE WITH A PAIR OF VISE GRIPS, then finish loosening it with the tube wrench.
Old Sep 23, 2005 | 06:45 AM
ebmiller88's Avatar
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
I listed the size wrenches I used in my brake and suspension swap here, read descriptions under the pics:
http://pg.photos.yahoo.com/ph/tarami...er72/my_photos
and here:
Ed
Old Sep 26, 2005 | 02:07 AM
3.8TransAM's Avatar
Car: 91 GTA, 91 Formula, 89 TTA
Engine: all 225+ RWHP
Transmission: all OD
Axle/Gears: Always the good ones
Note: Only try this after line refuses to come off normally and you have used penetrating oil.
You can actually clamp vise grips around the head of the flare wrench to keep it from spreading ot help break a frozen line free.
Like I said be careful and only do this after u try normal avenues and obviously ahve to have room to do it.
Some of the lesser experienced guys may not realize it and I thought it might help them out.
later
Jeremy
Old Sep 26, 2005 | 11:31 PM
Motor City Mike's Avatar
Car: '82 Trans Am
Engine: Blown 540 BBC
Transmission: TH475
Axle/Gears: Dana 60, 4.10 w/spool
The ultimate line/flare wrench:
You'll never round off, mangle/distort a flare nut with a set of these.
Old Sep 28, 2005 | 03:22 PM
Jetmeck's Avatar
WTF are those called ? Wouldn't work on a lot of our applications because you would not have room to turn it, however a smaller version might ?
Old Sep 28, 2005 | 05:37 PM
Car: '82 Trans Am
Transmission: TH475
They're called locking wrenches made by the Vise Grip brand name. They're also available in several sizes - I've got 2. The smallest version handles roughly 1/4 to 1/2" hex sizes, and are smaller than you might think.
billybob6110
Feb 11, 2016 10:41 AM
gord327
Sep 29, 2015 10:18 PM
romcjr
Sep 17, 2015 05:18 PM
Fox118
Sep 12, 2015 09:29 PM
FormulasOnly
Sep 6, 2015 10:42 AM
