Need FULL LS1 brake conversion
Old Jan 14, 2006 | 08:33 PM
Quick-IROCZ's Avatar
Car: 1987 IROC-Z28
Engine: 305 Tpi
I've seen this and that about different ways to do the front, the rear but through some unknown way, (flood/corrosion whatever it was because I just bought the fbody myself) all the brakes need replacing and I was hoping to kill several birds with one stone.
I'm looking to upgrade the front to some aftermarket rotors and LS1 calipers, and everything else from a 98+ camaro brake setup that I'll need. I'm hoping I can get the calipers in good condition but the rotors brand new to bring up the value of the car incase I sell it.
Then in the rear, I've decided to buy a 4th gen rear end from a junk yard, will there be a big difference in price from the LT1 rear to the LS1 rear? I heard it might cost $300 generally but I haven't gone to price one yet. Then after that what parts do I need to install the rear on an 87 IROC?
Finally getting LS1 brakes for the rear end, what are all the parts I need for that? Same way as the front, aftermarket rotors and factory calipers with hardware.
I would rather have gotten 4 brand new calipers but that would end up costing me an arm and a leg. Or would it? any alternatives I should know about?
For the full conversion how much has it costed you? Is $1,000 too cheap?
I don't mean to add more and more threads to tgo, I just got such a headache and i've been looking forever for all of this stuff.
-Quick
Old Jan 15, 2006 | 07:38 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
There are many threads on various brake conversions. You might consider a . Ed Miller is the resident brake guru.
JamesC
Old Jan 15, 2006 | 01:19 PM
Car: 1987 IROC-Z28
Engine: 305 Tpi
JamesC
I wouldn't have posted if I couldn't find what I was looking for. And doesn't ebmiller88 get enough emails a day about brakes? Every single one of these threads suggests him for help with a conversion. Honestly, I thought for sure i'd be BOTHERING him. If he wants to chat, by all means.
I searched through this brake forum all day yesterday and I couldn't find what I was looking for.
If anyone sees this thread, and knows exactly where some of these threads i'm looking for are, please oblige with a link or two.
Old Jan 15, 2006 | 04:07 PM
JamesC's Avatar
I searched with "LS1 brakes" in the brake forum and came up with four pages of info to include the following, which might prove helpful:
https://www.thirdgen.org/techbb2/sho...ght=LS1+brakes
By the way, Ed Miller has designed and sells various kits. Check with him for your needs. I'm sure he can hook you up.
JamesC
Old Jan 15, 2006 | 04:09 PM
Car: 1987 IROC-Z28
Engine: 305 Tpi
JamesC
Thank you, I'll check them out after I read how to swap the rear ends. There's so much reading to do.
Old Jan 15, 2006 | 04:17 PM
JamesC's Avatar
By the way, the 1LE option is also a good one, at least IMO. Spohn sells the front kit (Ed may too for all I know). You can mod the rear yourself. Check the following link:
https://www.thirdgen.org/techbb2/sho...hreadid=249098
JamesC
Old Jan 15, 2006 | 06:44 PM
Car: 1987 IROC-Z28
Engine: 305 Tpi
I curious JamesC, what's the reason you prefer the 1LE option disc brakes over the LS1 front and rear conversion? As far as I know, the LS1 has better stopping power.
Old Jan 16, 2006 | 02:09 AM
3.8TransAM's Avatar
Car: 91 GTA, 91 Formula, 89 TTA
Engine: all 225+ RWHP
Transmission: all OD
Axle/Gears: Always the good ones
I have both setups
Ls1 on the Formie and 1LE on the TTA. I'll take the LS1 setup any day.
They are both new and recently refurbushed, so the comparison is a fair one.
EbMiller is an awesome guy to deal with and he will take the time to answer questions as well as anything u buy from him is priced fairly
later
Jeremy
Old Jan 16, 2006 | 06:20 AM
JamesC's Avatar
I went with the 1LE's because that package was the only one available at the time (with the exception of the after market). I went with the rears, essentially because I wanted a matching set and also because I required a working e-brake. Without fabbing something up, I 'believe' this is a problem that still exists with LS1 brakes (not a biggie, I suppose, if you have an automatic). Futhermore, I didn't relish swapping the entire 4thgen rear end in because of its width--IMO, two inches a side is two inches a side too much. I also think there's a wheel fitment problem involved as well. Please double-check that info. At any rate, either the 1LE or LS1 or any of the other current packages will be far superior to the 10.5 Delco Moraine set-up you currently have.
JamesC
Old Jan 16, 2006 | 06:08 PM
DM91RS's Avatar
Car: 91 RS
I'm debating this myself...........which one is the least costly?
And............fabbing brake cables or anything else is no prob.
For what I spent on the front 1LE's knowing what I know now I could have had Wilwood 4pots for the price.
Old Jan 16, 2006 | 11:46 PM
Car: 1987 IROC-Z28
Engine: 305 Tpi
Well the rear end shouldn't cost too much from a junkyard but mine is all rusted up pretty bad so I was thinking of replacing. But i'm also under the impression I can sandblast it and the 1LE setup total would be cheaper. I don't know that for a fact. Wilwood is just TOO expensive.
Old Jan 18, 2006 | 01:56 AM
ebmiller88's Avatar
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
Priced a full rearend with brakes from a junkyard lately? The local yards here wanted $600 for a '94 LT1 disc posi. A private buyer would be better for you. If it's just rusty, clean it up.
The LT1 rear brakes are more of a direct bolt in and you won't have to mess with the e-brake issues, LT1 e-brakes are a no brainer...bolt right in and will give you good performance.
Replied to your PM.
Ed
Old Jan 19, 2006 | 05:35 PM
ebmiller88's Avatar
The issue is that when you utter the phrase "1LE", price goes way up. I have 1LEs, love them, and won't sell or get rid of them due to the time I have in them, the are one of the last sets of orginal GM 1LE parts, and if I tried to sell them I wouldn't get back what I have in them, there's just too many setups out there. BUT, they will fit wheels that other setups won't, such as GTA wheels. There's a plus and minus to practically all setups, it will depend on a number of things.
Least costly will depend on new or used parts. An all new LS1 setup will run you about $900, and all new 1LE setup is $850 from Spohn. Obviously a used setup will run less so it depends on where you get parts and if you can catch a deal.
PM me if you want my recommendations.
And to the orginal poster, IMHO $1000 is too cheap for both the front and rear setups unless you can do a lot of the machine work and modifications yourself. Again, it depends on a lot of factors.
Ed
Old Jan 19, 2006 | 06:37 PM
DM91RS's Avatar
Car: 91 RS
Thanks Ed. I really like the 1LE fronts. All original GM parts also as I started collecting for them in 1998.
Now I really need some rears to balance the setup and it probably will be one of the "L" setups. When I get around to it that is
DM
Old Jan 19, 2006 | 09:25 PM
Car: 1987 IROC-Z28
Engine: 305 Tpi
I can afford to go a little over 1k and around 1300 sounded good but I haven't decided on the C4 setup or any other setup for that matter, and just yesterday I came down with strep, so I probably won't make the deadline anymore. Although the car is the least of my worries. Either tomorrow or saturday i'm going to the local yards to see if I can quote a rear end.
If I decide to do business with you, I'll keep in touch. Thanks
Also, I do plan to do all of the labor, the only thing I can't do myself are modified spindles(i'm guessing, unless it's easy) and some heavy duty fabrication(if there is any).
Car: 1987 IROC-Z28
Engine: 305 Tpi
Old Jan 20, 2006 | 08:01 AM
JamesC's Avatar
Modification of the spindles for the 1LE set-up is relatively simple. If I remember correctly, all you need do is cut the ears off the spindle (hacksaw) and drill and tap two holes. You can purchase a CD from Spohn (at least it was available) or from AndyZ28, which details the mod. I accomplished the mod with the spindles off the car, but IIRC, some members did it with the spindles on car.
JamesC
Old Jan 20, 2006 | 04:10 PM
DM91RS's Avatar
Car: 91 RS
Ed
After reading again are you talking about the price for the fronts?
The rears should be a good bit cheaper than that correct?
Old Jan 20, 2006 | 04:18 PM
Car: 1987 IROC-Z28
Engine: 305 Tpi
I'd like to know that as well
Old Jan 21, 2006 | 02:01 PM
Car: 1987 IROC-Z28
Engine: 305 Tpi
I went to the junkyard today, nice place where they actually let you walk around and see the cars. Saw a few junked f-bodies. I was quoted 500 for a functional LS1 rear end(They'd have to get it from another yard). They were asking me what I planned to do with it and I told them. So then they showed me a 92 rear end with stock discs, which i'd never seen before. I thought they were rare. Anyway they were rusted up so I'm going to see if I can get this LS1 rear.
Do you think it's a good price and how much estimated should the front/rear swap cost total if the rear end was 500? This is nice, I'm finally getting somewhere.
Old Jan 22, 2006 | 11:31 PM
@ZZKKER's Avatar
Car: 86 iroc, 87 iroc, 89 iroc, 89 formula, 84 supra, 85 trans am
Engine: t\a motor 355 lt1 intake, t56,the works, 89 roc 427 sbc tt project
Transmission: to many to list
Axle/Gears: 9bolt 4:10 in the T/A
get on www.carpart.com and do a search for 98-02 f-body 6-speed rear (more likely to get a good rear ratio), and bypass the junk yard markup of the middle man
Old Jan 23, 2006 | 03:32 AM
Car: 1987 IROC-Z28
Engine: 305 Tpi
No dice, I went to the site and it only lists 93-02 camaro's disc rotors and shocks.
*edit 500 is THAT bad?
Old Jan 23, 2006 | 12:29 PM
ebmiller88's Avatar
Yes, the price I quoted was for fronts only. Again, the rears will depend on where you get them. The rear brakes usually go for $150-200 used, then factor a new set of rotors into that. Then you will have the issue of the e-brake cable hookup and brake lines to fit, especially onto a drum brake rear.
Still right at $1000 for all of it depending on where you get parts.
Ed
PS: IMO, $500 is too much in my book, maybe not yours.
Old Jan 23, 2006 | 04:42 PM
DM91RS's Avatar
Car: 91 RS
Thanks Ed.
I quess it's time to start gathering parts.
Depends on what I can find at the junkyards.
Old Jan 23, 2006 | 07:15 PM
@ZZKKER's Avatar
are you asking if 500 is a bad price for a whole rear end with brakes? If so i think 500 is not too bad if a local pickup can be made and it is the newer ls1 style brakes, then it wouldnt be a bad deal. You might try www.camaroz28.com and search the classified section for someone parting out a car or offering a rear for sale. You might be able to find a better deal that way as well.
good luck
sweet_87_iroc
Sep 25, 2015 10:01 PM
lt1z350
Aug 28, 2015 05:57 AM
86White_T/A305
Aug 17, 2015 12:16 AM
MustangEater82
Brakes
Aug 11, 2015 07:52 AM
