Line Lock Question
Old Mar 11, 2006 | 02:45 PM
crrllmich's Avatar
Car: 91 Camaro RS, 99 Camaro Z28
Engine: L03, LS1
Transmission: 700R4, T56
Axle/Gears: bunch of 10 bolts how scary is that
Line Lock Question
Quick question for you guy using line locks.
Is there anyway to make the linelock just disable the rear brakes so I can have full control of the burn out by power braking without screwing up my rear brakes?
Old Mar 11, 2006 | 05:21 PM
greezemonkey's Avatar
Car: A Portly 85 Z28
Engine: 4.530 X 4.250 BBC
Transmission: under rated for this application
Axle/Gears: also under rated
Ah yea, in a sense that`s what a line lock does, locks the fronts so the rear are "disabled" allowing you to do the burn out without taxing the driveline and rear brakes.
Old Mar 11, 2006 | 09:04 PM
crrllmich's Avatar
Engine: L03, LS1
Yes but I dont want to lock the front wheels at a 30 mph roll lol so is there anyway I can just have the linelock disable the rear brakes instead of just locking the front?
Old Mar 11, 2006 | 09:07 PM
crrllmich's Avatar
Engine: L03, LS1
Or even this will answer my question. If you enable the line lock without pressing the brakes in. Does it just disable your front brakes? Because if thats the case I could just install the line lock on the rear brake line.
Old Mar 12, 2006 | 07:34 AM
Well what ever your planning on a t 30MPH it sounds like a hazard..but try looking for an adujstable proportioning valve..summit sells them for around 40$ plumb it into the rear line and route it to the inside of the car, I`ve seen guys put them in the center console, I think you`d be able to dial down the pressure where they`d be useless that way.
Old Mar 13, 2006 | 01:10 AM
Profootbrake's Avatar
Car: 92 camaro Z28
Your brakes are separated into two systems most of the time you install the line lock on the front system only . When you use the line lock you press your brake pedal then hold the button for the line lock. Release the brake pedal and your front brakes remain locked and the rear is free to spin. Release the button and you brakes work like normal
Old Mar 13, 2006 | 07:50 AM
luvofjah's Avatar
Car: 91 Black Formula KR
Engine: 305 TPI R69/G92
I'm assuming (feel free to correct me), if you don't depress the brake all the way & use the line lock, the front wheels will be partially locked, and will allow to move forward slowly...
I'm a little confused as to what you're tring to do... 30 mph roll?? from standing still or slowing down..??
Rafael
Old Mar 13, 2006 | 08:11 AM
crrllmich's Avatar
Engine: L03, LS1
Rolling burnout...
Old Mar 13, 2006 | 08:15 AM
luvofjah's Avatar
I think partly depressing the brake and turning on the line lock will partially hold the front brakes on... and allow for your rolling burnout...
It's supposed to hold the pressure in the line, dependant on how much you apply before flipping the switch and letting the solenoid hold it..
Old Mar 13, 2006 | 06:17 PM
crrllmich's Avatar
Engine: L03, LS1
I just need it to not allow pressure to the line lol
Frozer!!!
Jan 19, 2024 04:55 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
Cameeeero
Sep 18, 2015 04:00 PM
Dialed_In
Aug 20, 2015 01:45 PM
redmaroz
Aug 16, 2015 11:40 PM
