Pulling
Old Apr 19, 2006 | 08:22 PM
xplane's Avatar
Car: 85 camaro sport coupe
Engine: 2.8 MFI
Transmission: v6 700R4 wish it was a 5spd Stick
Axle/Gears: Stock non posi 3.42s
Pulling
OK i know most are going to tell me that i need to bleed or instpect my brakes i have done this time and again, i even took it to a GM dealership and had it looked at. my brakes are working perfectly, but when i hit the brakes 50% i have a hard pull to the left and when i Hit the gas the car goes to the right just not as much. when i am not touching the gas or the brakes and the car is just coasting i have no pull the car tracks perfectly strait. i think that it is suspention related but when i ask on that board back before the update i was told to ask here. I had mostly just decided to let the issue go cause it wasnt that bad but it has started to get worse as time passes. I will ask this in the suspention forum again so if this is not a brake related problem just deleat this post.
Old Apr 19, 2006 | 08:32 PM
yjischoking's Avatar
Car: 95 Acura Integra GS-R
Engine: B18C1
Transmission: 5 spd.
did you replace the rubber brake hoses? otherwise, maybe it's the tie rods?
Old Apr 19, 2006 | 08:37 PM
xplane's Avatar
Engine: 2.8 MFI
yes everything from the hardlines out has been replaced. I just had the alignment done and the Balljoints/a-arm bushing/strutmouts were all replaced to get the thing to hold alignment.
Old Apr 20, 2006 | 07:11 PM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
LATE BRAKEING NEWS
Originally Posted by xplane
......everything from the hardlines out has been replaced. I just had the alignment done and the Balljoints/a-arm bushing/strutmouts were all replaced to get the thing to hold alignment.
<CENTER><B>
If it is the front left brake pulling it to the left you can verify.
Brake hard to see if the front left locks up first.
This would be consistent with the brake causing it to pull to the left. </FONT>
</B><FONT COLOR=F3399><H5>
“If people drove any slower they’d be going backwards.”</FONT>
<FONT COLOR=FF66FF></H5><H3>NINÅ</H3></FONT>
<P>
<TABLE BORDER=9 CELLPADDING=8>
<TD BGCOLOR=black>
<B><H3><CENTER>REFUSE
TO
LOSE<p></TABLE></CENTER>
Old Apr 20, 2006 | 09:35 PM
xplane's Avatar
Engine: 2.8 MFI
well i was driveing it today and i started hearing this scraping/grinding noise and the car started brakeing alot straiter and now the RR wheel is grabbing alot. it didnt lockup on pavement but anytime i hit the brakes on gravel it would slide that wheel. Is it normal for the car to go all squirly when ya hit the E-brake from about 10mph? i didnt pull it hard enought for it to lock but it went all wigley. jeeze i must still have something wrong with these dang brakes.
wigmobile
Feb 26, 2025 02:56 PM
83 Crossfire TA
Jan 3, 2016 01:26 PM
Amillionoh7
Sep 11, 2015 11:36 AM
sylentnite
Sep 9, 2015 02:55 PM
2012sergen11
Interior Parts Wanted
Sep 7, 2015 11:37 AM
