9bolt/10bolt brake lines
Old May 24, 2006 | 08:11 AM
net_coma's Avatar
Are the brake lines from the Tee block to the caliper/flex hose from my 9bolt compatable with a 10bolt & PBR calipers? (length and connection at the caliper?)
Almost have all the parts in hand to install the brakes this weekend.
Old May 24, 2006 | 08:38 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
The only difference between 9- and 10-bolt with PBR's is the backing plates. All else is the same.
JamesC
Old May 24, 2006 | 08:43 AM
net_coma's Avatar
I did not have PBR brakes. I replaced an iron caliper 9bolt with a 10bolt and decided to do the PBR upgrade along with the swap of the rear end. I know I need flex hoses and plan to pick them up after work. If I will need new hardlines also I wanted to get on the phone and find them so I can be sure of completing the work this weekend.
Old May 24, 2006 | 09:03 AM
JamesC's Avatar
This link should provide all the answers you'll need:
https://www.thirdgen.org/forums/faq-...iscs-89-a.html
JamesC
Old May 24, 2006 | 07:23 PM
net_coma's Avatar
I just picked up the pads and rotors...are they pads soooooooooo tiny when compared to what I removed...do I have the right ones?
Old May 25, 2006 | 06:58 AM
JamesC's Avatar
The pads should be for 89-92 (I assume for the performance package).
JamesC
Old May 25, 2006 | 08:44 AM
net_coma's Avatar
I measured the rotors (11.5") and compared them visually to pictures on here and when I looked at the pads I asked to see another set from another manufacturer and both were the same size and shape. I was surprised by what I saw as a small contact area and on disk brakes I have worked with the pad covers most of the machined area on the rotor. There is aproximately 1/2 inch of machined surface that will not be covered by the pad face. I did not have time last night to fit them into the caliper and check that fit.
Old May 25, 2006 | 09:00 AM
JamesC's Avatar
I checked at rockauto.com. They call the performance package 1LE.
JamesC
Old May 26, 2006 | 10:14 PM
net_coma's Avatar
JamesC....I have looked at pics and read your thread on brake conversion. On the drivers side the hard line goes into the l-bracket and connects to another line. What is this line...hard or flexable and there appears to be a fitting between the outboard line and the caliper. Is this fitting a threaded fitting similar to the one connecting the flex hose to the passenger side caliper? I zoomed the picture but there is not enough density to see this section clearly and Classic Tube does not provide a picture of the parts in their tube kit.
Thank you for the help.
Old May 27, 2006 | 07:44 AM
JamesC's Avatar
I added these pics, which you may find helpful, to the above link.
Driver's side:
https://www.thirdgen.org/forums/atta...g?d=1148733661
As you can see, the hardline goes to the bracket and the flex line goes from hardline/bracket directly to the caliper. No extra fittings are required.
Pass side:
https://www.thirdgen.org/forums/atta...g?d=1148734053
JamesC
Old May 27, 2006 | 02:03 PM
net_coma's Avatar
Thanks JamesC...I could not tell if that was a hard or flex line. I guess it is time to just order the kit. I was going to try and get what I have to work but after test fitting all on the drivers side I don't see it working. I really wanted to get it back on the road this weekend...such is life when doing modifications.
Reddeath210
Oct 6, 2015 08:20 AM
Warlocksirix
Sep 3, 2015 12:26 PM
Nj1987
Aug 19, 2015 08:26 PM
Leggman1
Brakes
Aug 12, 2015 08:39 PM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
