Car shakes when braking
Old May 27, 2006 | 10:46 AM
oifish's Avatar
Car: 1992 Camaro Z28
Engine: 5.7 TPI L98
If I have to hit the brakes suddenly the car shimmies a little bit then slowly pulls to the left as I hold on the brakes. I really have no idea where to start diagnosing this problem. Thanks.
Old May 27, 2006 | 12:12 PM
yuel's Avatar
Car: 91 z28
Transmission: 4l60
i sounds like your rotors are warped or pads on one side is bad/have more wear on it then the other side so when your braking one side is doing more stopping then the other side.
Old May 27, 2006 | 03:18 PM
oifish's Avatar
Engine: 5.7 TPI L98
what i noticed is that i hit the brakes and i can turn the right wheel for a couple of seconds. So i think the right brake line from the wheel to the rest of the system is clogged. (easy fix)
Old Jun 3, 2006 | 05:10 PM
ling427ttvette's Avatar
Car: 1983 Camaro Z28/1999 Cavalier
Just put new pads on and have the rotors turned, make sure the rotors are still in specification.. that should cure your problem. I bet money that your rotors are warped, and your brake pads have irregular wear because of it.
Old Jun 3, 2006 | 05:22 PM
92RS(real slow)'s Avatar
Car: 92 RS(sold) 1989 IROC-Z
Axle/Gears: ones that turn
yeah warped rotors are probaly the cause, but now a days most places wont turn rotors so you'll probaly be better off just buying new ones, you could have a caliper sticking though to if it is pulling to one side also
Old Jun 3, 2006 | 05:24 PM
Most places don't turn rotors? Take em to a shop, Auto Zone or O'reilly's, one of them should do it.
Old Jun 4, 2006 | 05:59 PM
MurcoRS's Avatar
Car: 1989 Camaro RS
Engine: ZZ4 350
Axle/Gears: BW 9-bolt w/3.73
Pulls that sudenly appear are usually due to hoses. They are cheap so replace them and bleed the system properly. I would try this first...
Old Jun 4, 2006 | 07:55 PM
oifish's Avatar
Engine: 5.7 TPI L98
Yea I noticed the only reason why it shakes it because as soon as i hit the brakes the car pulls to the left, so i suddenly get off causing the car to jump back to the right. I'll replace the hose and flush the system and see if that solves it. (btw what type of brake fluid do our cars use?)
Old Jun 4, 2006 | 09:05 PM
MurcoRS's Avatar
Car: 1989 Camaro RS
Engine: ZZ4 350
DOT 3
I recommend Castrol LMA brake fluid for street cars...
Old Jun 6, 2006 | 01:50 PM
Derek The Great's Avatar
Car: 1989 Firebird Formula
Engine: 305 T.B.I. (Vin tag "E" = LO3)
Transmission: THM-700-R4
Axle/Gears: 10 bolt posi 3.23
My car was doin the same thing, exept it pulled to the right.. figured it was the calipers, so i bought those and then i take the wheels off and notice the right front brake line had all sorts of blisters on it so i went n bought lineS, yes buy lines for both sides, because its like takin a shower n not washin your a$$, its kinda wrong.. n then i put the calipers n lines on together, and voila stops dead straight
Old Jun 11, 2006 | 09:47 PM
ksuburban's Avatar
all u have to do is machine the rotors. lube the caliper slides and put ac delco pads on. cheep aftermarket pads alone can cause a brake pull. if the lines look good then you dont need to change them. If a line was clogged then you would have a hard brake pedle and it would pull extreamly hard
Old Jun 12, 2006 | 03:50 PM
MurcoRS's Avatar
Car: 1989 Camaro RS
Engine: ZZ4 350
Hmmm, never seen or heard of that before!
You should patent those x-ray eyes of yours, you'd make a fortune!
No, not necessarily. The pedal would probably feel normal and depending on how the line is blocked would determine the symptom (ie. - return blockage would drag a brake, not pull)...
Frozer!!!
Jan 19, 2024 04:55 PM
Terrell351
Jun 13, 2021 01:13 PM
Adamki2000
Brakes
24
Dec 20, 2015 10:40 PM
kyleb24
Aug 15, 2015 08:24 AM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
