my c6 front brakes
Old Jun 4, 2006 | 09:56 PM
yuel's Avatar
Car: 91 z28
Transmission: 4l60
my c6 front brakes
just finished the c6 front brakes, its just the same as c5 but different design caliper
Attached Thumbnails my c6 front brakes-dscf0054.jpg   my c6 front brakes-dscf0057.jpg
Old Jun 4, 2006 | 11:01 PM
nascar2496's Avatar
Car: 1986 Camaro IROC-Z
Engine: 305 tpi
Transmission: BW t5 W/ short shifter
Axle/Gears: 9 Bolt 3.27 posi
very nice indeed
Old Jun 4, 2006 | 11:02 PM
Slave One's Avatar
Car: 1991 Camaro RS
Engine: 5.0 TBI
Axle/Gears: 3.08
Man, that looks good, how much did that set you back???
Old Jun 5, 2006 | 04:47 PM
kubihibi's Avatar
Car: 85 Monte Carlo SS
Transmission: 200R4
Looks sweet
Old Jun 5, 2006 | 07:44 PM
yuel's Avatar
Car: 91 z28
Transmission: 4l60
thanks, the whole thing with pads included cost about $550 tops, now including the labor and time it took me to do right and fix my stupid mistakes, about $2,000
Old Jun 15, 2006 | 09:11 PM
ScottyRS's Avatar
Car: 1992 Camaro RS
Axle/Gears: Stock
I'm interested. What was involved in getting those on? Do you have a link or something? And what about the rear brakes? Thanks.
Old Jun 16, 2006 | 12:33 AM
LT1LE's Avatar
Car: TWO 1992 CAMAROS 1 Z28 AND 1 B4C
Engine: 1 LQ9 AND 1 LS3
Transmission: 1 T-56 AND 1 6L90
Axle/Gears: 1 4.11 AND 1 3.31 (DANA 44)
THEY LOOK GOOD MAN... I HAVE C6 ZO6 BRAKES CALIPERS AND AP RACING ROTORS SITTING IN MY GARAGE RIGHT NOW (WAITING FOR MY DROP SPINDLES)
Old Jun 17, 2006 | 03:05 PM
livewire's Avatar
Car: 1983 Z/28
Engine: Edelbrock 355
Axle/Gears: 3.42/Zexel/PBR
Awesome! have a write up?
Old Jun 19, 2006 | 10:44 PM
yuel's Avatar
Car: 91 z28
Transmission: 4l60
these caliper use the same setup as c5 calipers, brackets, hubs, and rotors. just different lettering and stronger casting. they are the standard 2006 front brakes, they can be modded to be the F55 with brackets and 13.4" rotors, but the're not the Z06 brakes. here are links i used for the mod
How to Upgrade to 1LE brakes
https://www.thirdgen.org/forums/faq-...s1-brakes.html
here is my rears
Old Jun 21, 2006 | 02:14 PM
livewire's Avatar
Car: 1983 Z/28
I read in there that you need 91-92 Spindles, whats the difference between them and my 83 spindles?
Old Jun 21, 2006 | 02:19 PM
LT1LE's Avatar
89-UP SPINDLES ARE STRONGER THEN 82-88 SPINDLES.
BUT YOU DON'T NEED ANY SPECIFIC YEAR.
88-92 1LE SPINDLES ARE DESIGNED OFF 89-UP SPINDLES.
Old Jun 21, 2006 | 08:13 PM
livewire's Avatar
Car: 1983 Z/28
are these the 12.75 rotors Yuel?
Old Jun 21, 2006 | 09:18 PM
LT1LE's Avatar
FRONT:
STOCK C6 12.8" (SOME 16"WHEEL'S)
Z51 C6 13.4" (17"WHEEL'S)
ZO6 C6 14.0" (18"WHEEL'S)
REAR:
STOCK C6 12.0" (16"WHEEL'S)
Z51 C6 13.0" (17"WHEEL'S)
ZO6 C6 13.4 (17"WHEEL'S)
Old Jun 22, 2006 | 11:15 PM
livewire's Avatar
Car: 1983 Z/28
Cool, good to know the stock C6 brakes will fit under my 17" WS-6 rims. Thanks!
Old Jun 26, 2006 | 01:21 PM
kjgroen's Avatar
Car: Trans Am
Engine: L69
awsome!! Nice job!!
Old Jun 26, 2006 | 07:24 PM
IROCZman15's Avatar
Car: 1987 IROC-Z
Engine: 406 on N20 w/ EFI
Transmission: P.B. 700R4
Axle/Gears: 12 bolt w/ 3.91
awesome indeed, good work man, look great
Old Jun 26, 2006 | 07:54 PM
ebmiller88's Avatar
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
The only difference in C5 and C6 standard front brakes is the caliper casting, nothing more. Obviously the ZO6 brakes are totally different but the base setups are the same so they install the same, fit the same wheels, etc.
Ed
Old Jun 27, 2006 | 04:34 PM
livewire's Avatar
Car: 1983 Z/28
yuel, are the rears C5 brakes as well? i was having a hard time finding info on the rear brake swap, although i'm pretty familar with the C5 front swap.
Old Jun 28, 2006 | 09:01 PM
yuel's Avatar
Car: 91 z28
Transmission: 4l60
the brakes and axle are from a 97 lt1 setup. i just wanted to make it easy since the front brakes are the important ones, but they work good though.
Frozer!!!
Jan 19, 2024 04:55 PM
Terrell351
Jun 13, 2021 01:13 PM
Scorched1984
Wheels and Tires
66
Apr 16, 2016 06:56 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
