problem when i step on brakes.....
Old Jun 17, 2006 | 04:08 PM
Iroc_man's Avatar
Car: 87 Iroc
Axle/Gears: stock posi
i have a problem, when i am driving my car and i step on the brakes, the car pulls to one side, is there something with the brake pads or something worse? can anyone help me out?
Old Jun 17, 2006 | 04:45 PM
yjischoking's Avatar
Car: 95 Acura Integra GS-R
Engine: B18C1
Transmission: 5 spd.
if it pulls to the right theres something wrong with the left side (or vice versa). most likely, the rubber brake lines have cracked on that side and thus not enough caliper pressure. or the caliper has frozen. calipers are like 10 bucks for a reman at autozone. i would switch to stainless steel lines as well.
Old Jun 17, 2006 | 04:50 PM
Iroc_man's Avatar
Car: 87 Iroc
well that makes sense since the brake light inside the car stays on alot untill i step the brake sown to the floor, and then it comes on a little bit later.
Old Jun 17, 2006 | 11:17 PM
Engine: B18C1
yea..bleed your brakes too. the light will come on if there is heavily uneven pressure.
Old Jun 18, 2006 | 09:08 PM
Al Hasse's Avatar
Car: 1992 RS / 1989 RS
Engine: 3.1L MFI / Vortec 383 TBI
Transmission: T5 / LS-T56
Axle/Gears: 3.42 open / 3.73 Eaton posi
Mine were the same way, stepped on the brakes and the car would pull hard left. Both of the rubber lines up front were crackes all the way around, apparently the left one was holding more pressure. Here's what they looked like....
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
383cam
Sep 9, 2015 06:01 AM
Strick1
Sep 4, 2015 07:11 AM
andy74
Sep 3, 2015 08:41 AM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
