manual brakes!!!
Old Jul 9, 2006 | 11:28 PM
badbilly's Avatar
Car: 89 camaro rs
Engine: intercooled f1r procharged 383
Transmission: turbo 400
manual brakes!!!
i know it's going backwards but is anyone running manual brakes in a street and strip car? how did ya go about it? i know of a stock eliminator car running what looks like he just took the power booster off. do i need a different brake rod? thanks in advance.
Old Jul 29, 2006 | 12:27 PM
BlueBeast's Avatar
Car: 1985 Camaro
Engine: 565 BBC
Transmission: Glide
Axle/Gears: 9 inch/spool/3.70
i am looking into doing the same thing anyone have any advice
Old Jul 29, 2006 | 06:15 PM
ross's Avatar
Car: 82 camaro
Engine: 434 ci
Transmission: t400
Axle/Gears: 9'' 4.10 gear
I used ED Quay set up. removed the factory porportioning valve and installed an adj porportioning valve I also used the old brake light in the dash for the line lock activation light. This mod took 13 pounds off the car.
Old Aug 20, 2006 | 02:36 PM
tealsuzuki's Avatar
manual brakes ??????????
i was wanting to know if there is a link to this ED Quay set up and if any one has gone to manual brakes using the s-10 parts. my car is an 86 w/ 4 wheel disk. im getting ready to pull the motor to paint the firewall and would like to get rid of the clutter thanks alot
Old Aug 20, 2006 | 05:35 PM
BlueBeast's Avatar
Car: 1985 Camaro
Engine: 565 BBC
Transmission: Glide
HOME PAGE that will take you right to there home page and just click on the 82-92 camaro link
Old Aug 21, 2006 | 08:43 AM
badbilly's Avatar
Car: 89 camaro rs
i know alot of the stock eliminator guys use the s 10 manuel master cylinder, from early '80's i think.
Old Sep 1, 2006 | 12:25 AM
84Grn's Avatar
Car: 84 Pontiac Firebird
Engine: 368 6.0 LS
Transmission: 350 turbo+tci 3000 stall
Axle/Gears: 10 bolt 7.5 with 3.73 auburn posi-t
I want to do the same thing what do I need to do to get manuel brake system to work on my 84 firebird. I hate the booster and want it gone. So the 80's s-10 manuel brake master cylinder fit in our stock firewall with no mod.?
Old Sep 1, 2006 | 09:41 AM
badbilly's Avatar
Car: 89 camaro rs
ya need to fab a mounting plate and fit the shaht properly but i heard it isnt a big job.
Old Sep 4, 2006 | 05:23 PM
84Grn's Avatar
Engine: 368 6.0 LS
So only way to get the manuel brake system to work is to custom make mounting plate and lengthen the rod? Do I need to get different master cylinder no matter what?
Old Sep 4, 2006 | 07:34 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
A kit is the best way to do it.
I got a manual master cylinder from an S10 and bolted it right to the firewall through the brake pedel support. An adaptor bracket would make a cleaner and stronger mount.
The push rod needs to be shortened and relocated on the brake pedel. A power brake system has the push rod moving upward. You need to relocate the pushrod 1" higher on the brake pedel so that it pushes straight into the master cylinder. The relocation also increases the mechanical advantage for manual brakes. Older cars had 2 mounts on the pedal. Newer cars don't have a manual brake option so the second mount has been eliminated.
There's also a problem of brake lines. Third gen master cylinders have the brake lines on the engine side. All other GM master cylinders have the brake lines on the fender side. The ports are also a different size so you need to find adaptor fitting to make them hook up.
Why do you want power brakes? The booster is maybe 5 pounds so there's not a big weight saving. I converted to manual brakes mostly for the extra room under the hood.
1992 Trans Am
May 10, 2023 07:19 PM
Terrell351
Jun 13, 2021 01:13 PM
Vintageracer
Jan 10, 2020 05:33 PM
kyleb24
Aug 15, 2015 08:24 AM
1992 Trans Am
Aug 8, 2015 08:16 PM
