SSBC Master Cylinder.
Old Nov 12, 2006 | 05:14 PM
1 DwnCam's Avatar
Car: 92 Z28 Camaro
Engine: Procharged 406.
Axle/Gears: Moser 9" 4.11 Gears
Can I use any of the following M/C from SSBC?
http://www.ssbrakes.com/products/sea...illet+Aluminum
Old Nov 15, 2006 | 06:28 PM
1 DwnCam's Avatar
Car: 92 Z28 Camaro
Anybody??
Old Nov 15, 2006 | 10:27 PM
ebmiller88's Avatar
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
Yes you can.
Ed
Old Nov 16, 2006 | 09:34 AM
1 DwnCam's Avatar
Car: 92 Z28 Camaro
From the link above. Is there one in particular?
Old Nov 16, 2006 | 12:19 PM
norcalz28's Avatar
Car: 1989 Camaro IROC-Z
Engine: ZZZ# 0607 of 1200 produced
Transmission: Pro-Built 700R4/Vig.2400
Axle/Gears: 3.27 BW 9 Bolt PBR Disc
Didn't SSBC just come out with an adjustable master cyl?
Ed, in running the c4 brakes on my third gen, would you recommend an adj prop valve, or stick with stock 1LE prop valve? Just curious. I have a wilwood unit, but I'm a little hesitant to cut up my lines. Thanks
Will
Old Nov 19, 2006 | 01:33 PM
1 DwnCam's Avatar
Car: 92 Z28 Camaro
Anybody know which size is the right one for our cars?
Old Dec 12, 2006 | 03:48 PM
1 DwnCam's Avatar
Car: 92 Z28 Camaro
How about what bore M/C comes stock on 82-92 camaros?
Old Dec 12, 2006 | 08:30 PM
BOTTLEDZ28's Avatar
Transmission: A4
or you could run this one instead
http://www.nastyz28.com/forum/showth...ghlight=master
Old Dec 12, 2006 | 08:58 PM
trumps2000's Avatar
Car: 1985 Z28
Transmission: T-5 5 Spd
Axle/Gears: Built 10bolt w/3.73s
norcalz28, I'm running a C4 front setup too and am using an adj. prop valve. I love this setup stops on a dime. I will warn ya, I have it setup to almost max pressure reduction for the rears. When I tested it, the rears would lock before fronts pretty easily with too much pressure.
I couldn't cut my stainless lines so what I did was left the factory valve in place, but removed the prop guts and replaced it with the 5/8" plug (do a search for "prop valve mod"). Then I plumbed the adj between the master and factory valve. This way I could always put things back together stock later.
Old Dec 12, 2006 | 10:40 PM
ebmiller88's Avatar
Will
CPP did.. link is posted above.
Personally, I'd just run a 1LE spec valve unless you just want to have more adjustability. The stock design works great, my car stops very well with full 1LEs and 1LE spec master and prop, no other mods.
Ed
I believe stock is 7/8"-1" but I havent' seen deifinte proof. I think there was a thread a while back on it, I'll look and post up later.
Ed
Last edited by ebmiller88; Dec 12, 2006 at 10:41 PM. Reason: Automerged Doublepost
manualbrakes.com
Brakes
63
Apr 9, 2024 11:55 AM
Fireslash
Apr 11, 2016 06:43 PM
jaridjohn
Oct 5, 2015 07:01 AM
meeklay812
Oct 1, 2015 03:46 PM
usafirebird
Sep 29, 2015 11:58 PM
