LS1 REAR caliper bracket->backing plate bolt size
Old Nov 14, 2006 | 06:53 PM
spartyon's Avatar
Car: 1986 camaro
Engine: 383 sbc
Transmission: th-400
Axle/Gears: 4th Gen 10 bolt/Detroit TrueTrac 4.
I have searched relentlessly over the last 2 days and cannot find the bolt size for the caliper bracket to the parking brake assembly backing plate. I ordered the fronts through fastenal but now I need the rears.
Long story short. Attempted to install c5 rear brakes with the c5 bracket and bolts but the brackets don't fit and the bolts for the corvette are larger than the bolts for the LS1s.
Any help is much appreciated!
Peter
Old Nov 14, 2006 | 07:33 PM
ebmiller88's Avatar
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
Be right back, I'll check for ya.....
(sound of running feet......)
It's a M12 x 1.75 x 30mm bolt, C5s use a M14 x 2.0 bolt
Ed
Old Nov 14, 2006 | 07:54 PM
spartyon's Avatar
Car: 1986 camaro
Engine: 383 sbc
Once again, you da man Ed!
Old Jan 8, 2008 | 08:46 PM
Craig84Z's Avatar
Car: 1984 Camaro Z28
Engine: Blueprint 383
Re: LS1 REAR caliper bracket->backing plate bolt size
Ed
Is this the backing plate to axle flange bolts? Not sure because he talks about the caliper bracket.
Old Jan 8, 2008 | 11:03 PM
ebmiller88's Avatar
No, that's the abutment to backing plate bolt. The bolts that hold the backing plate to the axle are around 7/16" or so. Again, I can check those I have in the shop.
Ed
Old Jan 9, 2008 | 05:24 AM
Craig84Z's Avatar
Oh, okay. Thanks for double-checking for me sometime soon
Old Jan 9, 2008 | 12:33 PM
ebmiller88's Avatar
The bolts that hold the backing plates onto the rearend are standard 3/8"-16 by 1 3/4" in length.
Ed
Old Jan 9, 2008 | 03:31 PM
Craig84Z's Avatar
Thanks Ed.
MoJoe
Fabrication
Aug 19, 2017 07:12 PM
sailtexas186548
Jan 19, 2016 12:21 PM
sailtexas186548
Brakes
Aug 13, 2015 11:47 AM
MustangEater82
Brakes
Aug 11, 2015 07:52 AM
knight72
Aug 10, 2015 09:32 PM
