big cam and brakes
Old Dec 14, 2006 | 02:08 PM
WheelsUp84z's Avatar
Car: 91 z28
Engine: 383 sbc, 88mm turbo a2w IC, CSU 750
Transmission: th-400 PTC 4000 stall
Axle/Gears: ford 9" 3.55 gear
big cam and brakes
i got a 91 z28 and im switching from tpi to a carb set up, im running a custom ground comp cam 265/276 dur @.050, .601/.594 lift with 1.6 rockers, on 110 lsa solid flat tappet, im worried about this cam being so big that when i get on the brakes hard it will draw all the vacuum from the engine and stall out, just wondering what my options are, might i have to run some sort of vacuum pump for the brakes? any help would be much appreciated
Old Dec 14, 2006 | 02:30 PM
dennisbernal91z's Avatar
Car: Building LS3, T56 Z28
Engine: LS3
Axle/Gears: Moser/ 4.11
I have a big *** cam too. I just run a vacume canister. Works like a charm and only cost $30. At high speed, you are more than OK, in parking lots and traffic is where it can get bad, the canister takes care of that. Stores all the vacume for later use. Vacume pumps are over rated, or so I hear. I had a thread just like this a few weeks before I got my new motor. 500HP 385.
Old Dec 14, 2006 | 03:09 PM
Car: 91 z28
damn sounds like were pretty close..im building a 500 horse 385 sbc too got a part number for that vacuum canister? here did you mount it at? for as many times as ive read through your CD site i thought i would have seen that.....lol thanks a bunch though
Old Dec 15, 2006 | 07:41 AM
Engine: LS3
Nice. Well for a cheap one get: CCA-5200 , thats what i got.
If you want a pretty one, get CCA-5201, it is the same, but polished.
If you still want it even nicer, there are others out there. The first is $44 and the pretty one is $65. This is all from summitracing.com. I mounted mine on the DS wheel well under the hood. I will include a pic.
Old pic, but you can see it right there in the middle.
Here is a more recent pic, you can see the lines going to and from it. Took me 10minutes to toss in and I also got the liquid filled guage for it too. Nice to see the vacume build and get used up when I hit the brakes.
Hope this helps. Lemme know if you have more Q's.
Old Dec 15, 2006 | 12:19 PM
Car: 91 z28
damn that thing is big and ugly...i might have to go with the pretty one cuz that things just wont do for me!
Old Dec 15, 2006 | 12:31 PM
pizza_guy's Avatar
Car: 84 Z28 H.O. w/Megasquirt II
Engine: semi-stock L69
Transmission: T-5 non W/C
Axle/Gears: 3.73 open
Could it be mounted behind the front bumper instead, like where the stock one goes?? If so, that ugly one will look a lot more at home there.
Just my
Old Dec 15, 2006 | 01:35 PM
Engine: LS3
Good idea. Yeah it can be mounted wherever. I never thought about moving it. I just put it there, cuz it was just plain convenient. Over the winter, I plan on moving things around and making them look pretty. In the pics, it is just me slapping it all togeather to get it up and running. But yeah, behind the bumper, or hell, even behind a fender, or under the hood latch. There are tons of places to hide it, and if you do hide it, you might want the black one, it will stay hidden much better.
Old Dec 15, 2006 | 04:05 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
That doesn't happen. You just don't get nice soft brakes, they're hard as a rock.
That canister is massive! Holy cow, they should post a scale picture on summit, I thought it'd be a lot smaller.
I figure the only time you really "need" it is when you're at high RPM (WOT), no vacuum and very quickly jump from gas to brakes.
If you're at part throttle you should have enough vacuum for brakes, at idle and WOT is where its dicey.
Old Dec 16, 2006 | 03:41 PM
Engine: LS3
or in a parking lot when you are using and not using the brakes a lot
Orr89RocZ
Apr 25, 2016 08:28 AM
sweet_87_iroc
Sep 25, 2015 10:01 PM
overdriv
Aug 20, 2015 03:52 PM
cstrobel65
Aug 15, 2015 10:19 AM
