Rear disc emergency cable
Car: 89 RS, 92 Z28
Engine: 305 TBI, 350 TPI
Transmission: 700R4 Both Cars
Axle/Gears: 3.23 Posi.. 4 wheel disc both cars
Do you have to have the emergency brake cable on rear disc brakes in order for the brakes to work properly....??? Thank you very much for any answers, Tom
Car: 89 RS, 92 Z28
Yes, I know they are different...I have both...My question is do you have to have the emergency brake cable to make the brakes work peoperly??? I thought I read somewhere that it was involved in adjustment, or something....Thanks, Tom
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
i do not think you need the cable to get the brakes to work, generally there is adjustment in the parking brake mechanism that needs to be adjusted to get the e-brake to function properly, but like i said the brakes should work fine. i do not however recommend driving without a functional e-brake. i just did my ls1 rear brake swap and the parking brake, while a different design, does not have any affect on the actually functionality of the brakes, and need adjustment to work properly. does this help?
Car: 89 RS, 92 Z28
86TA, thanks for the answer....I dont think i've ever used a e-brake in my life on an automatic car, but I have the cable, so why not...I was just wondering about it....Thanks again, Tom
Car: 1985 Iroc-Z
Engine: 440LSX
Transmission: l460e
Axle/Gears: 3.55 Wavetrac
You need to start using the emer. brake with the factory rear disc. They keep the acutator free and in working condition. I had a long talk with a 30 year experianced brake mechanic on these types of brakes. Using the emer. brake and keeping it adjusted properly will help keep the rears in working order. These brakes are not the best but hey, it's what comes on the car. Badman
Car: 89 RS, 92 Z28
Hey Badman, I had read something along that line before..i just could'nt remember what it was tho....Are these brakes any better than the drum brakes that came on my car???? I know they will look better with my wheels, but will my car stop any better??? Thanks, Tom
Car: 1985 Iroc-Z
Engine: 440LSX
Transmission: l460e
The factory 4-wheel disc are not the best unless your car has the newer style. I donot know what year the upgrades came out, suggest you do a search in the brake forumn. I upgraded to the LE1 brake system this year. They are much better than the original Delco Moraine. As for braking, disc is always better,stays cooler, less fade. Again, go with the newer style calipers and rotors. You will be much happier and have better stopping power. Badman
Car: 89 RS, 92 Z28
Well I guess I dont have the newer one, it came off of an 87 Iroc..The brakes were kinda a bonus as I wanted the posi that was in the car...I guess I will live with it tho..Thanks, Tom
Car: 1991 camaro RS
Engine: CharlesOdoryOB
Transmission: 82513892892
Axle/Gears: pbr disc 3.27 nine bolt
the rear brakes useing the hydralics are seperate to the cable driven park brake so the answer you
no ebrake has nothing to do with functional rear brakes
edit never mind this info only applys to pbr rear brakes
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
You need to start using the emer. brake with the factory rear disc. They keep the actuator free and in working condition. Using the emer. brake and keeping it adjusted properly will help keep the rears in working order. These brakes are not the best but hey, it's what comes on the car.
https://www.thirdgen.org/forums/faq-...iscs-89-a.html
JamesC
hectre13
Dec 11, 2023 08:14 AM
sailtexas186548
Jan 19, 2016 12:21 PM
