rear brake locking up?
Old Mar 14, 2007 | 04:46 PM
puntank4200's Avatar
Car: '88 Camaro
Engine: v6-173-2.8L
Transmission: Automatic
I recently added gear lube I my differential and changed my fuel filter, and had to jack up the rear and applied the e-brake. A few days earlier I installed a new header gasket, while I was installing it I found myself accidentally posting of the master cylinder.
Today I put in reverse back up, then in drive but, it feels like something is holding my car back. I give it some gas and it the feeling subsides sorta. When accelerating from a stop, I can hear my rear right (passenger) brake whining like it were depressed. The sound you can hear when you apply gas and brake at the same time.
The sound is definitely coming from the rear right drum, but not the left. Do you think I pinched the rear right brake line or did I pinch the e-brake cable. If I pinched a brake line would it stay depressed all the time? Or did I screw something up on the master cylinder? I did drive it after I replaced the gasket and I never noticed, but after I got done the lube and filter change I noticed it. So I'm almost 100% sure that the problem is due to the jacking of the rear and nothing to do with the master cylinder, but I thought I should inform you of all the possible causes.
Old Mar 14, 2007 | 05:57 PM
Car: '88 Camaro
Engine: v6-173-2.8L
Anybody?
Here's an update, I checked the back brake lines and the driver's side not the passenger's side was pinched? Would this cause the passenger side to feel locked?
Old Mar 14, 2007 | 09:05 PM
sully91rs's Avatar
Car: 91 RS, 95 Z28
Engine: 305 tbi, 350 lt1
Transmission: 4l60, 4l60e
Axle/Gears: monsterous 2.73s in both
If your drivers side is pinched, it would restrict pressure to the drivers side, making the passenger side feel like it is locking up.
Old Mar 14, 2007 | 09:26 PM
MurcoRS's Avatar
Car: 1989 Camaro RS
Engine: ZZ4 350
Axle/Gears: BW 9-bolt w/3.73
You doubled the pressure to the passenger side, locking it up and possibly damaging the wheel cylinder.
Old Mar 15, 2007 | 02:39 PM
Car: '88 Camaro
Engine: v6-173-2.8L
I changed the line and bleed the back brakes but now my parking brake light stays on?
Old Mar 15, 2007 | 03:30 PM
bilms01's Avatar
Car: 89 Firebird
Engine: 350 Ramjet
Axle/Gears: GM 9 bolt 3:27
make sure the master cylinder is full. If it is low the brake light will come on
Old Mar 16, 2007 | 05:16 AM
MurcoRS's Avatar
Car: 1989 Camaro RS
Engine: ZZ4 350
More likely you have air in the line or a loose fitting, which sets off the pressure differential switch in the prop valve and turns on the dashboard "brake" light. Check you rear lines and rebleed the system.
Old Mar 19, 2007 | 08:12 AM
Norwood's Avatar
Car: 89 z
Engine: Chevy 383
Axle/Gears: 9 bolt 3.73
The spool in that prop valve must be centered in the middle during normal operation (when you have equal line pressure to front and back).If you lose pressure to one side, the high pressure side pushes it to the far end of travel turning on the brake light. It is a major pain to recenter the spool due to sludge or corrosion sticking it in the bore. Usually it won't come back on its own and needs to be removed and knock it against a block of wood several times on each side to free it up.
Frozer!!!
Jan 19, 2024 04:55 PM
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
SpaniardV6
Brakes
19
Sep 7, 2015 03:04 AM
kyleb24
Aug 15, 2015 08:24 AM
