LS1 front brakes caliper-to-carrier bolts question
Old Jun 5, 2007 | 06:30 PM
Xophertony's Avatar
Car: 2012 Nissan Leaf
Engine: 80-kW AC synchronous electric motor
Transmission: Automatic
Axle/Gears: n/a
well, after reading every single page of the FAQ i have a question i do not think was covered, asked, but not answered. the bolts that bolt the caliper to the caliper abutment bracket (carrier). i have not seen a part number anywhere. can anyone help me out? this is one of the last parts i have yet to acquire before a can start my swap.
thanks much.
Old Jun 5, 2007 | 08:29 PM
spartyon's Avatar
Car: 1986 camaro
Engine: 383 sbc
Transmission: th-400
Axle/Gears: 4th Gen 10 bolt/Detroit TrueTrac 4.
Re: LS1 front brakes caliper-to-carrier bolts question
Bought mine on GMPartsDirect.com. I can't remember which one it came with. Either the pin or the boot kit.
Caliper Pin 12530697 $3.73 4
Caliper Boot Kit 12530703 $3.12 4
If the bolts aren't with either of those, then they came with my new Z06 calipers. Check into those part numbers. If you need anymore I documented everything I bought so don't hesitate to ask.
**I just checked those part numbers and mine actually came with the calipers new. This should be the part number for the individual bolts in which you will need 4, #14067559. Good Luck!**
Old Jun 6, 2007 | 02:46 PM
Xophertony's Avatar
Axle/Gears: n/a
THANKS!
that was the last# i needed.
Old Jun 6, 2007 | 05:41 PM
greezemonkey's Avatar
Car: A Portly 85 Z28
Engine: 4.530 X 4.250 BBC
Transmission: under rated for this application
Axle/Gears: also under rated
LS1 caliper to carrier bolts are longer than C5`s...you won`t be able to use those with the LS1 caliper.
Old Jun 8, 2007 | 01:36 PM
Xophertony's Avatar
Axle/Gears: n/a
sighhhh..... dang it. so does anyone have the part number i need. the GM dealership was NO help at all.
Old Jun 8, 2007 | 02:20 PM
espirocz's Avatar
Car: CTS-V & 89 Z28 vortech charged
Engine: LS6 & 383 charged stroker
Transmission: 6-speed & 5 speed
The bolts that mount the caliper to the caliper pins are a part # 18026153 2 per caliper 4 total per front brake setup. Call your local GM dealership PARTS deptartment and ask them to check the part # 18026153 . Retail on these bolts is $18.84 each!! ouch! Tim.
GM includeds these bolts in their pad kits!!! If you go with aftermarket pads you might get these bolts you might not! Try calling your local auto parts chain store and see if they have pads and if their included. Or order your pads from GM and you will get these bolts!
Old Jun 8, 2007 | 04:00 PM
Xophertony's Avatar
Axle/Gears: n/a
i don't suppose anyone knows the length size and thread pitch of these bolts. i don't have to use legit GM fasteners...
big thanks espirocz. if no one knows the size i'll just buy one and then go match it up.
heeeey.... why don't i just hit the junkyard for a bolt to match up...
Old Jun 8, 2007 | 05:58 PM
how bout I just mail you 4 new ones, I have them, they are 8mm x1.25 x 18mm with a flange hex head with green loctite applied. PM details.
Old Jun 12, 2007 | 01:34 PM
Xophertony's Avatar
Axle/Gears: n/a
got your PM.
THANKS!!!! for posting up the thread pitch and sizees. now anyone else who needs these in the future and does a search will come across this thread (which i titled appropriately) and will have their answer. i am going to add this to the FAQ.
Old Jun 12, 2007 | 08:21 PM
Xophertony's Avatar
Axle/Gears: n/a
yeah.... no, no they are not. 20 MM is not even long enough to go through the caliper holes....
thread pitch and 8mm is correct.
EDIT*
i went with 25MM long.
Old Jun 12, 2007 | 09:04 PM
Well, here at my desk I do not have a digital caliper to make it easy for some to read but here is a LS1 and a C5 caliper bolt, you can clearly see that the LS1 bolt is longer than the C5 and if you can read the caliper, it is roughly18mm in length and the C5`s is considerably shorter, along the lines or 14mm
Attached Thumbnails LS1 front brakes caliper-to-carrier bolts question-dscf0102.jpg   LS1 front brakes caliper-to-carrier bolts question-dscf0103.jpg
Old Jun 24, 2007 | 08:46 PM
Xophertony's Avatar
Axle/Gears: n/a
uhhhh... you are reading your caliper wrong. here, let me show you.
you see, since the measurement ticks don't start until a little ways in (10CM i am guessing) the "0" marker is there so you know where to start measuring, but you measured right at the edge of your jaw, so your measurement was off.
Frozer!!!
Jan 19, 2024 04:55 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
Scorched1984
Wheels and Tires
66
Apr 16, 2016 06:56 PM
sailtexas186548
Jan 19, 2016 12:21 PM
sailtexas186548
Brakes
Aug 13, 2015 11:47 AM
