Need an scan of parking brake adjust
Old Aug 12, 2007 | 10:49 AM
Theking's Avatar
Car: 1989 IROC-Z
Transmission: Th700R4
Hi
is there anyone that have the Camaro shop manual and can make an scan of the parkingbrake adjustment for me ?
I really need one i think its on the page 5-16 in the shop manual 1985.
please
http://irocz.info.se/
Old Aug 12, 2007 | 11:10 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: Need an scan of parking brake adjust
Sorry, I can't scan for you. The adjuster on the your 85, however, is forward in the tunnel above the drive shaft.
JamesC
Old Aug 12, 2007 | 11:14 AM
Theking's Avatar
Car: 1989 IROC-Z
can you take a photo of it ?
Old Aug 12, 2007 | 11:35 AM
JamesC's Avatar
Anything for the Swedish contingent . This following pic was posted by ebmiller88:
https://www.thirdgen.org/forums/atta...e-adjuster.jpg
JamesC
Old Aug 12, 2007 | 04:10 PM
Theking's Avatar
Car: 1989 IROC-Z
thanks. its solved and found now
Old Aug 28, 2007 | 01:24 PM
xbcrguy182x's Avatar
I have also been having a problem with my ebrake. First, it doesnt work. I tried adjust the nut on that thing under the car. I turned it right, almost all the way. No go. However, i think that black bracket was just hanging off, instead of bolted to the body. Could that be the reason why its not working?
Old Sep 9, 2007 | 09:14 PM
di11avou's Avatar
Car: 1988 Camaro
Engine: 305ci TBI
The black bracket doesn't actually bolt to the car. The tension on the cables is the only thing that holds it in place. Make sure the front cable is clipped into place (bottom circle). Also make sure the 2 rear cables are slipped into the tabs/holders on each side of the driveshaft tunnel (top 2 circles). If the cables aren't in these holders, it will seem like the cables are too long.
Attached Thumbnails Need an scan of parking brake adjust-e-brake-adjuster-cirlce.jpg
Old Jan 6, 2008 | 02:38 PM
Im still trying to figure out this problem. If I turn the nut, the whole screw thing moves with it. is it suppose to do that? I dont think so.
Old Jan 7, 2008 | 01:11 AM
ebmiller88's Avatar
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
You have to hold the long screw with a wrench on the flats near the cable while turning the adjustment nut. Make it easy on yourself and soak it with penetrant long before you try it again.
Ed
Old Jan 7, 2008 | 11:52 AM
Thanks, that sounds helpful. I'll give it a shot this weekend. I just wish i have more room under there, im fighting with the exhaust and driveshaft....why GM, WHY?!!?!?!
1992rs/ss
Jan 31, 2025 05:10 PM
Frozer!!!
Jan 19, 2024 04:55 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
MustangEater82
Brakes
Aug 11, 2015 07:52 AM
