Cailper,hose install ??
Old Sep 27, 2007 | 07:29 AM
ron91rs's Avatar
Car: 91 rs
Engine: 3.1 v6
This is probably common sense to u-all but , being new i dont want to screw anything up.
My question is, can i (should i ) assemble my new break hose to the new front caliper off the car, then install to hard line OR do i have to for some reason install the new hose to the hard line first, then install the caliper to it?
Seems like i would loose more fluid doing the later...
Also , do all pads have to be bedded in??
Thanks for your advice...
Old Sep 27, 2007 | 11:47 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: Cailper,hose install ??
You might find it's hard to tighten the banjo bolt with the caliper off the car.
Old Sep 27, 2007 | 07:02 PM
ebmiller88's Avatar
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
If you have a bench vice slide the caliper into it so that wont' turn and install the new hose with a new bolt and crush washers, then install on the car when you can.
Ed
Old Sep 29, 2007 | 09:01 AM
ron91rs's Avatar
Car: 91 rs
Engine: 3.1 v6
Thanks guys, thats todays project...right after i finish installing these @#$%$#@# springs...
1992 Trans Am
May 10, 2023 07:19 PM
lakeffect2
Aug 23, 2015 08:44 AM
BurlyChev
Aug 22, 2015 01:52 PM
1985chevydude
Aug 22, 2015 05:36 AM
1985chevydude
Aug 20, 2015 12:29 AM
