brake upgrade and springs
Old Nov 30, 2007 | 06:21 PM
avro206's Avatar
Car: 89 Formula
Transmission: TH 700R4
Quick question....If I am going to do both these upgrades....is it best to do them at the same time?
Because the front struts have to come off for each procedure....right?
I
Old Nov 30, 2007 | 08:58 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: brake upgrade and springs
Originally Posted by 871LEIroc
Quick question....If I am going to do both these upgrades....is it best to do them at the same time? Because the front struts have to come off for each procedure....right?
Yes and yes, if the spindle requires modification for the brakes (though some have done the mod on car).
JamesC
Old Nov 30, 2007 | 10:55 PM
J's T/A's Avatar
Car: 82 Trans Am
Engine: LTX
Axle/Gears: 3.42 strengthed 7.5 inch
What he said, I replaced springs, bushings, ball joints, and tie rods while I had it apart for brakes..
for the next upgrade it is bushings and ball joints.. almost preventative but while I have access I want to just do it.
Old Dec 1, 2007 | 01:22 PM
ebmiller88's Avatar
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
I also recommend doing it while it's all apart, just do it once.
Ed
Old Dec 4, 2007 | 09:52 PM
avro206's Avatar
Car: 89 Formula
Ed
Ed can you pm me price for C5 front brakes? I sent you a PM but maybe you've been busy.
thanks
Mike
Old Dec 5, 2007 | 05:28 AM
ebmiller88's Avatar
I'll check and reply or resend..thanks!
Ed
PS: I HIGHLY recommend the Eibach Pro kit, my Iroc is on rails with 36/24mm bars and poly bushings.
Old Dec 5, 2007 | 03:59 PM
Dockrocker's Avatar
Yes, do it at the same time.
Also, a good hint if you really want to clean parts while you have them off of the car (way away from the car) is oven cleaner. CAUTION, this will take off paint and everything, sometimes it may take a few applications, and use care not to get it on yourself (espicially in your eyes) or anything you don't want stripped down. Then clean with soap and water, dry and paint right away before it starts rusting.
Old Dec 5, 2007 | 04:12 PM
ryan91rs's Avatar
Car: 1991 RS, 84 El Camino conquista RIP
Engine: 5.0 (for now)
Transmission: 4L60
Axle/Gears: 2.xx torsen limited slip & 3.42 ope
Ed could you also PM me for the C4 HD setup. I would like to know the price and maybe a link to how it can be done. Thanks!
Frozer!!!
Jan 19, 2024 04:55 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
deracer
Apr 11, 2016 12:04 AM
gta90
Sep 15, 2015 04:00 PM
zayne0
Aug 24, 2015 07:22 PM
