I switched to rear disks.....
Car: 1987 Trans Am
Axle/Gears: 4.10's
I switched to rear disks and had a question about the prop valve. The guy I bought the rear disks from gave me the brake master cylinder along with the brakes. He told me all I need to do is swap out his master for mine and it will work fine because the prop valve is built into the master. Is this true? They look the same, but the part numbers are different. Just want to make sure.
Car: 81z-28,89gta,91z-28 03 1500
Engine: 355,L98vette tpi,327
Transmission: TH350/700R4/700r4/4l80E
Axle/Gears: 3;73/3;27/2;73/3;73
Re: I switched to rear disks.....
Car: 1987 Trans Am
Axle/Gears: 4.10's
A local site is telling me to install a prop valve even with the rear disk master. I just want what was from the factory. I know GM didn't splice in a prop valve.lol
Car: 89 RS Convertible
Engine: 305 tbi
Transmission: 700R4,B&M friction,Transgo shiftkit
Axle/Gears: 2.73 LSD
i beleive the prop valve and residual pressure valve are in the distribution block right under the master, drum and disc blocks look very different from eachother. you could probably grab one from a junkyard and just connect the lines.
Car: '91 Firebird Convertible
Engine: 305 TBI (LO3)
Transmission: 700r4, Vette Servo
Axle/Gears: 3.27 9 Bolt, PBR disks
They are differnt. I just know.
However, I have heard that either will work with the disk rear. To be safe, use the disk rear prop valve (that can be had either with or without the MC itself).
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Just curious. What rear discs did you swap to, Delco-Moraine or PBR's?
JamesC
JamesC
Car: 1987 Trans Am
Axle/Gears: 4.10's
I have the iron calipers.
Here is what the guy gave me..
Is this the on with the factory prop valve?
I saw the prop valve install in the tech section, what about the brake sensor? thats why I want the factory stuff.
JamesC
Car: 1987 Trans Am
Axle/Gears: 4.10's
Yep. He said the distribution block (pictured) had the proper prop valve for rear disks. I want to make sure what he says is true.
If the master and proportioning valve came from the same car that the discs came from, then there is not problem.
JamesC
JamesC
1992 Trans Am
May 10, 2023 07:19 PM
