Pulling only 6lbs of Vaccuum
Old Jul 1, 2008 | 03:54 PM
M1tch's Avatar
Car: 1989 Iroc Z
Engine: 496 BBC
Transmission: th400
Axle/Gears: 4.11
I just did a motor swap in my 92' Camaro RS to a 358. I have an edelbrock performer rpm and a comp xr270. the intake is only making 6lbs of vaccuum for the brake booster. normal is around 24-30. what could be the problem?
Old Jul 2, 2008 | 08:33 PM
ebmiller88's Avatar
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
Re: Pulling only 6lbs of Vaccuum
Too big of a cam/engine combo. Look into an electric vacuum pump and reservoir to hold more vacuum.
Ed
Old Jul 2, 2008 | 09:49 PM
rjt76's Avatar
Car: 1986 iroc z
Engine: vortec 383
Transmission: th350
Axle/Gears: 3.73 moser 12 bolt true trac
what is the duration of that cam? I doubt its too big.
Old Jul 3, 2008 | 08:42 AM
SteelTownMadDog's Avatar
That's the same cam I'm running and have at least 15" of vacuum at 750 RPM idle and no problems with my power brakes. You have a bad leak somewhere. Maybe you're brake booster is busted, or your vacuum gauge is. At 6" of vacuum, the engine will be running like total crap.
Old Jul 3, 2008 | 12:45 PM
M1tch's Avatar
Car: 1989 Iroc Z
Engine: 496 BBC
Transmission: th400
Axle/Gears: 4.11
I did realize that we had a port used for cruise control but we took cruise control out. So thats 12" of vaccumm leaking.. But do you think theres more to it? * and the motor does seem to run rough
The cam is a Comp XR270
Intake is Performer RPM
Old Jul 4, 2008 | 07:25 AM
Yes, that's the same cam & intake I'm running.
Are you sure all the unused ports & intake are plugged? If so, then you have a cracked hose somewhere.
Old Jul 5, 2008 | 07:37 AM
M1tch's Avatar
Car: 1989 Iroc Z
Engine: 496 BBC
Transmission: th400
Axle/Gears: 4.11
We did degree my camshaft 2 degrees retarded. I'm not sure if that would make a vaccum difference? It makes a top end difference though
wigmobile
Feb 26, 2025 02:56 PM
83 Crossfire TA
Jan 3, 2016 01:26 PM
Amillionoh7
Sep 11, 2015 11:36 AM
sylentnite
Sep 9, 2015 02:55 PM
MSgt Luttrell
Sep 5, 2015 11:28 AM
