rear pbr bolt kit??
Old Aug 6, 2008 | 07:41 PM
rv1890's Avatar
Car: 87 Iroc-Z
Engine: 5.7 350 TPI
Transmission: stage2 700r4
Axle/Gears: 2.73 for now
rear pbr bolt kit??
Ok..I got a disc rear end and 10 bolt backing plates from ebmiller. Im about to get a pair or pbr disc calipers from someone on this site, but it doesnt include the mounting bolts. What do I order??....The only relative parts I can find are the rear caliper "bolts" and the rear caliper "pin boot kit"....even if these parts are correct I dont know how they mount..anyone got a pic or an exploded view??
The left are the bolts , and the right is the "pin boot kit"....any bushings needed like the front discs use or is this equivalent to the pic on the right?
Attached Thumbnails rear pbr bolt kit??-caliper-bolt.jpg   rear pbr bolt kit??-pin-boot-kit.jpg
Old Aug 6, 2008 | 08:42 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: rear pbr bolt kit??
I did the conversion. The following may be helpful:
https://www.thirdgen.org/forums/faq-...iscs-89-a.html
Your pic shows caliper parts, not mounting hardware.
JamesC
Old Aug 6, 2008 | 10:09 PM
rv1890's Avatar
Car: 87 Iroc-Z
Engine: 5.7 350 TPI
Ive read that thread a hundred times and it has helped me with getting the parts I need for my disc swap. However, I just read it again and I dont see where it mentions anything about mounting hardware. I need the bolts that mount the calipers to the backing plate.
Old Aug 7, 2008 | 06:08 AM
JamesC's Avatar
Maybe a hundred and one times . From the link:
"I used grade 8 bolts from CarQuest to mount the backing plates to the axel flanges--check the first link for appropriate sizes. Carrier to backing plate bolts are GM (P/N 10164181)."
JamesC
Old Aug 7, 2008 | 10:24 AM
rv1890's Avatar
Car: 87 Iroc-Z
Engine: 5.7 350 TPI
I already have that. My backing plates are already mounted to the axle with the bolts that ebmiller sent with the backing plates. I need the mounting hardware for the caliper to the backing plate. For example the front uses 2 allen head bolts to attach the caliper to the hub. I need whatever it is for the rear
Old Aug 7, 2008 | 10:38 AM
JamesC's Avatar
I I need whatever it is for the rear
Note the p/n above. These attach the caliper carrier to the backing plates. The following is a pic, although you can only see one of the two bolts (the carrier is red. Could it be that you're missing that part?):
https://www.thirdgen.org/forums/atta...s-89-shims.jpg
JamesC
Old Aug 7, 2008 | 01:12 PM
rv1890's Avatar
Car: 87 Iroc-Z
Engine: 5.7 350 TPI
There we go...sorry about that JAmes. I think your right. I might be missing the carriers. Where can I get those and what do they look like?....So i need the carriers and the bolt kit (GM (P/N 10164181). Heres a pic of the calipers. The carriers r missing right?
Old Aug 7, 2008 | 02:56 PM
JamesC's Avatar
I recently ordered a caliper from Advance Auto and it came with the carrier in place. Check this link for a pic:
http://www.partsamerica.com/ProductD...e=5003&PTSet=A
You're missing the carrier. Yes, you need it and the bolts. By the way, the pictured calipers are missing the e-brake lever, spring, bracket--all difficult to locate individually, I'd think. If you haven't purchased yet, you might reconsider, or use them as cores. The caliper I mention above not only came with the carrier, but everything but the spring.
JamesC
Old Aug 7, 2008 | 06:12 PM
rv1890's Avatar
Car: 87 Iroc-Z
Engine: 5.7 350 TPI
Thank James. Dont know if you have noticed, but u have been helping throughout this swap. You thread and info. has been very helpful. Thanks again. ......cant wait for 3.73's and 4 wheel discs!
hectre13
Dec 11, 2023 08:14 AM
Terrell351
Jun 13, 2021 01:13 PM
ZMWojnar
Brakes
May 12, 2019 10:43 PM
Eric-86sc
Apr 3, 2016 03:52 PM
hectre13
Aug 26, 2015 08:17 AM
