Pedal to the floor!!!OH NO I CANT STOP
Old Oct 23, 2008 | 11:41 PM
greg320's Avatar
Car: 1992 Camaro Z28 Convertible
Engine: L98 TPI
Axle/Gears: GM 10 bolt, 3.42GM
OK all,
I have replaced almost my whole braking system, new calipers, rotors , pads, master cylinder, lines. Pedal goes to the floor, very unsafe. Bled several times no help. I am going to replace the booster. Anyone have any suggestions other than the booster?
Old Oct 24, 2008 | 08:17 AM
UNCLE TOM's Avatar
Car: 91 R/S , 89 dodge p/u
Engine: L31 GM crate re-cammed , 318
Transmission: T-5 , 4 speed auto
Axle/Gears: 3.42 , ?
Re: Pedal to the floor!!!OH NO I CANT STOP
it's obvious you still have air in the system . did you pre-bleed master cylinder ? have you tried a pressure bleeder ? good luck .
Old Oct 24, 2008 | 12:24 PM
kcb37's Avatar
I had a friend with an 87,
had a bad booster, pedal would go to the floor ( don't know if it actually touched it or not) but to stop it, it did take a whole lot of pressure. It was almost like it didn't have any brakes at all.
Old Oct 24, 2008 | 04:44 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
um, no
if he had some air in the system it would be spongy and the pedal would pump up. It goes right to the floor, the booster is most likely shot. Or the pushrod came off the pedal.
Old Oct 25, 2008 | 03:35 AM
greg320's Avatar
Engine: L98 TPI
Put in a new booster today.. no help. I should mention this is a drum to disc conversion in back. Starting to think the rear calipers are crap, even though they are new. They are the old style GM Eldorodo caliper from the '80s. The kit came from POL. I am thinking of using EB Millers banjos to switch to PBR. Anyone have any thoughts on this.. Thanks.
Old Oct 25, 2008 | 11:35 AM
//<86TA>\\'s Avatar
Car: 86 Trans Am
you swapped the booster already, the big black thing on the firewall behind the master? wow you work fast. irregardless of the brakes, the pedal should not fall right to the floor. Something is still wrong with the booster/pedal/master assembly
Old Oct 25, 2008 | 12:08 PM
Brennan's Avatar
Car: 1984 Z28 HT,2006 2500HD
Engine: 5.7L, 6.6Llbz dmax
Transmission: 700R4, 6 speed allison
Axle/Gears: worn out 3.73 posi
i had this problem once and it turned out that one of my calipers was leaking around the piston
Old Oct 25, 2008 | 02:41 PM
greg320's Avatar
Engine: L98 TPI
I guess a leak in possible, I will check that. Anyone have any idea if a 1LE master cylinder might help? The only master cylinder with a different part number is the 1LE. I am thinking it moves more fluid for the larger brakes.
Old Oct 25, 2008 | 04:48 PM
iansane's Avatar
Car: '91 TA vert
Engine: turboLSx
Does the pedal just drop to the floor with no resistance? Or does it sink quickly like before you bled it. I'd bet on it not being bench bled/vacuum bled and there is still air in the lines. Pick up a mityvac from the autoparts store and you'll wonder how you got along without it. Or try pulling one line at a time out of the master cylinder and capping the hole to see if it's the MC or what wheel is giving you the issue.
I hope I don't come off sounding like a douche but people using the prefix-abbortion 'irregardless' is one of my pet peeves. That's not a word. Regardless is though.
Old Oct 25, 2008 | 09:43 PM
Brennan's Avatar
Originally Posted by iansane
prefix-abbortion
for some reason that hit me really funny. thank you, i needed a good laugh
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
manualbrakes.com
Brakes
63
Apr 9, 2024 11:55 AM
ctoledo0834
Sep 18, 2015 04:16 PM
Night rider327
Sep 2, 2015 04:18 AM
Night rider327
Sep 2, 2015 04:17 AM
