Rust rings
Old Nov 1, 2008 | 09:16 AM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Transmission: 700R4/T-56
Rust rings
What causes this?
Bad rotors? Pads? MC? Distribution block?
These are actually new pads and rotors.
Old Nov 1, 2008 | 10:18 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: Rust rings
Looks pretty normal to me.
Old Nov 1, 2008 | 10:50 AM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Re: Rust rings
Normal? Something's got to be wrong.
I have 3 other cars that have rear discs and none of them have these rings.
Old Nov 1, 2008 | 11:09 AM
Guest
Guest
Posts: n/a
Re: Rust rings
What are you referring to? The area near the edge of the rotor?
Old Nov 1, 2008 | 01:12 PM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Re: Rust rings
Yes. It's on the inside and outer diameters on both sides of the rotors on both rears.
Old Nov 1, 2008 | 02:39 PM
Guest
Guest
Posts: n/a
Re: Rust rings
The inside will rust unless its painted. Usually there's a groove before the surface area gets to the center 'hat' of the rotor. The outside on the pad surface area looks like its not machined right, like the outer last part is thinner than the rest. I've seen that before.
Old Nov 2, 2008 | 05:21 AM
UNCLE TOM's Avatar
Car: 91 R/S , 89 dodge p/u
Engine: L31 GM crate re-cammed , 318
Transmission: T-5 , 4 speed auto
Axle/Gears: 3.42 , ?
Re: Rust rings
the brake pads contact the rotor to stop the car . they do not contact the full rotor . the area they contact remains polished from pad contact . the area they do not contact is subject to surface rusting . NORMAL . good luck .
Old Nov 2, 2008 | 09:21 AM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Re: Rust rings
Poor engineering.
Thanks.
Old Nov 2, 2008 | 11:17 AM
DJP87Z28's Avatar
Car: 1987 Black IROC-Z (SOLD)
Re: Rust rings
You either have the the wrong pads or screwed up rotors. My rear PBR brake rotors are completely cleaned up after a few stops. check picture.
Fireslash
Apr 11, 2016 06:43 PM
LT1Formula
Oct 8, 2015 08:34 PM
gord327
Oct 3, 2015 01:25 PM
FormulasOnly
Oct 2, 2015 05:52 PM
Numbah-1
Oct 2, 2015 08:27 AM
