9 bolt rear PBR brakes using C5 rotors possible?
Old Jan 7, 2009 | 05:37 PM
Daz's Avatar
Daz
Car: 87 Camaro
Engine: Chevy V8
Transmission: auto
IIRC I can just get ed's backing plate and this will work?
What do I do about e-brake?
Old Jan 8, 2009 | 01:56 PM
ebmiller88's Avatar
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
Re: 9 bolt rear PBR brakes using C5 rotors possible?
No, the C5 rotors are too thick for those calipers and the radial dimentions are wrong.
Ed
Old Jan 8, 2009 | 07:25 PM
Daz's Avatar
Daz
Car: 87 Camaro
Engine: Chevy V8
Transmission: auto
hey ed, I have LS1 brackets, abutment and C5 conversion brackets.Do you have a backing plate that will work?
Thanks for the info man
Old Jan 9, 2009 | 06:48 PM
ebmiller88's Avatar
Please clarify, front or rear parts?
Ed
Old Jan 10, 2009 | 11:35 AM
Daz's Avatar
Daz
Car: 87 Camaro
Engine: Chevy V8
Transmission: auto
Ed
All the LS1 parts are for the front..
Old Jan 10, 2009 | 03:14 PM
George's Avatar
Car: 83WS6TA
Engine: ZZ4
Transmission: TH350C
Axle/Gears: 3:23
Old Jan 13, 2009 | 04:59 AM
Daz's Avatar
Daz
Car: 87 Camaro
Engine: Chevy V8
Transmission: auto
What I have
C5 rotors
LS1 front calipers/abutments
9 bolt rear with PBR brakes
C5 pads
Since I need rotors it would be nice if I can just upgrade to C5 brakes in the back
I have 18" Z06 wheels in the back if it matters
Old Jan 15, 2009 | 09:13 AM
Daz's Avatar
Daz
Car: 87 Camaro
Engine: Chevy V8
Transmission: auto
hi
Old Jan 16, 2009 | 03:57 PM
ebmiller88's Avatar
Originally Posted by Daz
What I have
C5 rotors
C5 pads
Well hey there...
The C5 rear brakes aren't as bolt on friendly as LS1s are, the backing plate bolt patterns are totally different. Here's some progress I made a while back but this is currently set up for a drum rear:
https://www.thirdgen.org/forums/brak...ear-c5-c6.html
I apologize for not having them finished yet and it's too cold now to get to them so I'll get back to them when it warms up a bit. Until more progress is made, you can buy C5 rear conversion plates from Kore3 (~$750 for the plates) or just convert to LS1 rear discs which are very close to C5s, only slight differences in the two. Also, since you have a 9 bolt, that bolt pattern is different from the LS1 pattern as well, another issue there. Since you already have PBRs out back, I'd recommend increasing rear disc size (13" or so) and running C5 or larger front discs that will fit your 18" wheels. A 14" C6 ZO6 rotor with either LS1 or C5/C6 front calipers would work nicely for you.
HTH...
Ed
Old Jan 17, 2009 | 06:59 AM
Daz's Avatar
Daz
Car: 87 Camaro
Engine: Chevy V8
Transmission: auto
Well hey there...
HTH...
Ed
So I guess all I need a the plates to install my C5 rotors and LS1 front brakes then?Ill go for the 14" rotors if possible too.Take youre time Ed and thanks for the support.
Old Jan 17, 2009 | 07:44 AM
ebmiller88's Avatar
Basically yes, along with a couple other things and some details.
Hubs, mods to spindles, custom conversion brackets for a 14" rotor and LS1 caliper and abutment, new brake lines/banjo bolts, LS1 pads (LS1 calipers = LS1 pads). Good luck!
Ed
Old Jan 17, 2009 | 02:46 PM
Daz's Avatar
Daz
Car: 87 Camaro
Engine: Chevy V8
Transmission: auto
Ed
spindles?dude Im only talking about mods to my current rear PBRs .I already have C4HD for the front.. Get those plate done ED!!! hehe
Old Apr 4, 2009 | 04:05 AM
Daz's Avatar
Daz
Car: 87 Camaro
Engine: Chevy V8
Transmission: auto
Well hey there...
HTH...
Ed
any luck on the plates Ed?
custom backing plates are all I need to use the 13" C5 rotors correct?Along with LS1 calipers etc of course.
Old Apr 5, 2009 | 10:37 AM
ebmiller88's Avatar
Yes, plates for 13" rear discs using the '89-97 PBR calipers are done.
Ed
Old Apr 6, 2009 | 02:31 PM
godreject's Avatar
Car: 09 GSXR/88 iroc/91 RS B4C
Engine: 600cc/l5.7/5.7
Transmission: 6 speed/TH 350/auto
Axle/Gears: 45tooth rear?/3.23/3.42
Hey Ed interested in those 13" rotor brackets for pbr brakes, any pics, price and when can i order, i need them for my 19 C6 rims, what else will i need besides the rotorsand plate, i currently have the pbr set up on my 91
Old Apr 7, 2009 | 08:46 PM
Daz's Avatar
Daz
Car: 87 Camaro
Engine: Chevy V8
Transmission: auto
Ed
Can you pm me the price for the brackets and everything else that I might need for the rear
I think I need rear flex lines too.
Old Apr 11, 2009 | 07:53 PM
Daz's Avatar
Daz
Car: 87 Camaro
Engine: Chevy V8
Transmission: auto
bump..april 10th
Old Apr 13, 2009 | 04:28 PM
ebmiller88's Avatar
bump..april 10th
PM sent.
Ed
Old Apr 16, 2009 | 10:10 PM
Daz's Avatar
Daz
Car: 87 Camaro
Engine: Chevy V8
Transmission: auto
hey ed,
I think Ill go for plates that I can use the LS1 calipers/C5 rotors instead.
check your pms
Old Apr 23, 2009 | 08:04 PM
ebmiller88's Avatar
Let me be clear, the C5 rotors won't swap in with the LS1 backing plates/abutments and then bolt to a 9 bolt, there's a few differences in designs that won't allow it. The C5 and LS1 rotors have a slightly different offset and the LS1 plate has a different pattern than the 9 bolt. I was referring to the earlier '89-97 LT1/1LE/J65 rear disc design prior to the LS1 rear discs in '98-up. As usual I'll see what I can make fit but at this time you can't do that without a custom backing plate.
Ed
smnichol86
Brakes
26
Mar 26, 2017 10:55 PM
BADNBLK
Brakes
Oct 6, 2015 02:51 PM
loud91rs
Oct 5, 2015 10:05 PM
the_hamturdler
Sep 30, 2015 12:50 PM
dbrochard
Sep 25, 2015 04:56 PM
