uneven brake wear
Old Jan 13, 2009 | 10:49 AM
RED_DRAGON_85's Avatar
Car: 85 Camaro IROC
Engine: 5.7 TPI
Transmission: 700-R4
Axle/Gears: open rear, 3.42 gears
uneven brake wear
what would cause the driver side brakes to wear less than the passenger side brakes?
the driver side was at about 1/4" remaining, pass was at about 1/8" remaining.
just installed new pads but i would like to resolve this problem if possible.
Old Jan 13, 2009 | 03:46 PM
cavazos31's Avatar
Car: 1988 camaro sports coupe
Engine: Fast Burn 385
Axle/Gears: 9 bolt w/ 3.27 gears
Re: uneven brake wear
Never encountered that problem, but perhaps something is wrong with your drivers side caliper since the passenger side seems to be braking harder and using up more pad. Does the car pull right?
Old Jan 13, 2009 | 11:43 PM
Car: 85 Camaro IROC
Engine: 5.7 TPI
nope.
steering stays (or more correctly, stayed) perfectly light and didnt pull even under hard braking.
could it be a difference in the pads?
Old Jan 14, 2009 | 07:32 AM
UNCLE TOM's Avatar
Car: 91 R/S , 89 dodge p/u
Engine: L31 GM crate re-cammed , 318
Transmission: T-5 , 4 speed auto
Axle/Gears: 3.42 , ?
this might sound off the wall to you but its normal . RF brakes wear a little more than the others . in other countries that drive on the left side of the road the LF brake wears first . road crown and other factors cause this . some of our aussie & japanese members can back this up . i found this to be true after i drove my american car several years in japan . what a challenge to drive a full size american car in japan . good luck .
Old Jan 14, 2009 | 09:11 AM
paulo57509's Avatar
Car: '87 IROC
Engine: LB9
Transmission: TH700R4
Q: Are the inboard and outboard pads in each caliper wearing evenly?
Old Jan 14, 2009 | 02:05 PM
Car: 85 Camaro IROC
Engine: 5.7 TPI
no, one was more worn but i cant remember which and i threw the pads away.
i think it was the outboard pads that wore more.
also, i was thinking that driving on the right might have something to do with it.
if you are turning left, the right pad will do more "work" because the outer wheel is turning faster than the inner wheel...
who knows.
Old Jan 14, 2009 | 09:07 PM
paulo57509's Avatar
Car: '87 IROC
Engine: LB9
who knows.
I asked about the pad wear within each caliper because this is an indication that the calipers aren't sliding along the mounting bolts.
The uneven pad wear between each caliper could be an indication that one caliper isn't free to slide.
Old Jan 15, 2009 | 08:35 AM
Car: 85 Camaro IROC
Engine: 5.7 TPI
could it also be an indication that i need new brake lines?
i figure if there was a restriction in one line that would account for it...
BADNBLK
Convertibles
Sep 21, 2015 07:56 PM
dbrochard
Sep 19, 2015 08:13 PM
lock1983
Brakes
Sep 9, 2015 09:08 PM
Buickstaged
Brakes
Sep 4, 2015 07:53 AM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:50 PM
