Swapping rear calipers?????
Car: 1987 IROC-Z
Transmission: TH700-R4
Axle/Gears: Stock 9-bolt with 3,27 Posi
Hi Guys,
I`ve got a question regarding my rear disc brakes.
Is it possible to swap the rear calipers from a 1984 Z for the newer ones , I believe from 88-up.
Because I hate those E-brakes and every year they`re stuck again when I go for the annual road check.
Thanx in advance
Rene
P.S. or is there a better solution , in other words aftermarket calipers or something????
Thanx in advance
Rene
Car: 1985 Iroc-Z
Engine: 440LSX
Transmission: l460e
Axle/Gears: 3.55 Wavetrac
Re: Swapping rear calipers?????
I replaced my 85 discs in the rear with the later model PBR's. You will need to change the backing caliper mounting plates. Use EB Miller's stuff. Here's the link to his site or search on the brake board for him.http://www.flynbye.com/ is his website.
Car: 1985 Iroc-Z
Engine: 440LSX
Transmission: l460e
Pic of rear PBR's.
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
https://www.thirdgen.org/forums/faq-...iscs-89-a.html
JamesC
Car: 1991 RS
Engine: 383 stroker
Axle/Gears: 3.23 posi
I need to do this swap as well. I checked out the firelines site and it looks like the part number changed to FRA8901SS (unless I'm wrong). It says you'll need a hose between the caliper and hardline. Doesn't the hard line screw right to the caliper?
Finelines. I'd about half forgotten. Check my ride out on their home page.
JamesC
Car: 1991 RS
Engine: 383 stroker
Okay...I know I'm having brainlock....but what the **%# does PBR mean anyway? Thanks for the reply, I'm pretty **** when it comes to rebuilding this car and I want to do it right. I just pulled a rearend from an 84Z w/disk and I'm guessing it's just smarter to upgrade instead of overhauling. This is still the part I'd need though, right?
JamesC
Car: 1987 IROC-Z
OK guys thanx for the input
So I need backing plates too so there is no easier solution without changing backing plates right?????
Or are there calipers from another car that will fit rightaway or any aftermarket calipers that will fit????
I`m asking this because I`m on the other side of the big pond (Europe) and shipping heavy parts such as brake parts is pretty expensive.
Thanx again
Rene
Thanx again
Rene
JamesC
Car: 1987 IROC-Z
OK Thanx , I will be looking for a parts car over here first
but if I can`t find one I will try to locate some parts in th US
Thanx again
Rene
Thanx again
Rene
Eric-86sc
Apr 3, 2016 03:52 PM
sailtexas186548
Jan 19, 2016 12:21 PM
25thannivZ28
Aftermarket Product Review
Jan 2, 2016 05:41 PM
