upgrade questions
Car: 88 Iroc
Engine: 383
Axle/Gears: 3.43
upgrade questions
i was looking to upgrade my rear drums to disc what companys is a good place to buy parts and what would i all need to do this????
Car: 1987 IROC-Z Camaro
Engine: L98 5.7L TPI
Transmission: 700-R4
Axle/Gears: 3.27 BW
Re: upgrade questions
http://www.flynbye.com
Owned and operated by thirdgen.org's own ebmiller88. He sells a rear drum to disc conversion and all kinds of front brake solutions.
Depending on your axle though, you might want to just keep it drums until you can find a better replacement. When you can pick up a 4th gen axle for $200 disc-to-disc with posi, spending $85 for the brackets plus new calipers, rotors, pads, and everything else (If you have a posi, it might be worth upgrading brakes, but if you have an open diff with drums, find a whole new axle.) gets really expensive really fast.
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
https://www.thirdgen.org/forums/tran...-10-bolts.html
JamesC
Car: 91 camaro RS, 87 T/A
Engine: 350 TBI, 305 TPI
Axle/Gears: 4th Gen 3.42/BW 3.45
I would say go out and grab a 4th gen rear form a JY. mine cost me 300$ and i got the PBR discs and a 3.42 posi. Its usually cheaper than upgrading just your brakes. Maybe you can snag a LS1 rear with those 12 inch discs also. But pretty much if your looking to go anything different than that ebmiller is the place to go. Hes a god with brakes but hes busy so be patient.
Car: 89 IROC
Engine: 305 TPI / ZZ4 cam
Transmission: Stage 2 700R4, LS1 driveshaft
Axle/Gears: Strange 3.42 w/ Auburn
Car: 88 Iroc
Engine: 383
Axle/Gears: 3.43
hey guys thanks for the info another one for yall can i use a 4th gen master cylinder for disc brakes so i dont have to buy a new valve???
NinjaNife
Aug 23, 2015 11:49 AM
