fluid coming out of brake reservoir
Old Jul 26, 2009 | 06:53 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
i've noticed, ever since i swapping in a ls1 master cylinder, that after a drive there is always brake fluid on the reservoir. Its coming from the cap, but the seal is in great shape, no cracks tears ect. Any ideas? If the master was bad could it be pushing fluid back into the reservoir?
Old Aug 11, 2009 | 12:53 PM
racing geek's Avatar
Car: 1987 IROC-Z
Engine: 383 with Edelbrock ProFlow EFI
Transmission: TH350
Axle/Gears: 12 bolt 3.73 Eaton posi
Re: fluid coming out of brake reservoir
Did you ever solve this?
Old Aug 11, 2009 | 12:56 PM
91interceptorZ's Avatar
Car: 91 B4C "police special service"
Engine: L98 494hp
Transmission: tko-600 on order
Axle/Gears: 3.23 true trac
curious what the purpose of using an ls1 master cyl is......upgrade from stock???
Old Aug 11, 2009 | 03:45 PM
gregsz-28's Avatar
Car: 85 Camaro
Engine: No
Transmission: No
Axle/Gears: No
IIRC, it is used because the fittings are on the same side as the stock MC, and it is better for rear discs.
Old Aug 11, 2009 | 04:05 PM
Engine: L98 494hp
like converting to rear disc???...is it an upgrade if you already have rear disc???
Old Aug 11, 2009 | 04:07 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
i have not figured it out yet, the reservoir is not overfilled as far as i cat tell, but there is always from leakage after i drive, comes from under the cap on the driverside, runs down onto the wheel well and down to the base of the firewall.
the master is a upgrade overstock, almost a direct bolt on.
Old Aug 11, 2009 | 05:19 PM
Car: 1987 IROC-Z
Transmission: TH350
What are the benifits... what makes it an upgrade? I've been reading that it has better internal baffles but is there anything else? What are the benifits of better internal baffles?
All I really want to know is if it is narrower then the stock part. I've read that it is ~1/2" shorter (closer to the firewall) but I can't find any info on the width. I'm running enough camber right now that I have to pull off the master cylinder cover just to adjust my koni strut. Can you help with this?
Thanks,
Mike
Old Aug 11, 2009 | 05:54 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
I'd like to know as well.
JamesC
Old Aug 11, 2009 | 06:11 PM
gregsz-28's Avatar
Car: 85 Camaro
Engine: No
Transmission: No
Axle/Gears: No
I don't know much about it, but I assume the benefit of better baffles would be that the fluid would move around less and pick up less air.
Old Aug 24, 2009 | 10:33 AM
BadaPwned's Avatar
Car: 1984 TA 15th Anniv. Addition
Engine: 355 SBC
Transmission: TH350
Axle/Gears: 4.56
Not sure what brake setup you have, but a possible solution is the pistons in the calipers are retracting back into the caliper too far. ei, their not staying adjusted.
I have this problem currently, my rear calipers wont stay adjusted so I have to push the pedal twice to get the rear pistons to the discs.....so when the pistons come all the way back into the caliper all the fluid the pistons displaced comes out of master cylinder.
This may be your problem.
Old Aug 24, 2009 | 06:18 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
havent thought of that one, but im quite sure its not the issue. The pistons seem to stay adjusted. even if they didnt, disc done use a lot of volume to operate, just pressure.
as for my setup, its the stock booster, LS1 master, 1le prop, c5 zo6 fronts, ls1 rear discs.
kyleb24
Aug 15, 2015 08:24 AM
Street Lethal
Aug 12, 2015 11:33 AM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
Leggman1
Aug 6, 2015 04:15 AM
