1LE brakes info need help for conversion
Old Sep 18, 2010 | 12:55 AM
DiabloWS6's Avatar
Car: '86 TRANS-AM WS6
Engine: 1989 355 TPI L98
Transmission: TH700R-4
Axle/Gears: BorgWarner 9 bolt/ 3.27
is the front 1LE option brake setup for 1989 irocs and gta's the same from a 1989 c4 corvette the 12" setup and if so can u just go get it from a corvette instead of buying from the internet cause i know a guy who basically fixes and parts out c4 corvette and i can get it from him at a much cheaper price if they are like a direct bolt on with spindle and disc ect. so if any one knows about this let me know cause im trying to convert my 1986 trans-am into 1LE front brake conversion so if u know share the knowledge thanks
Old Sep 18, 2010 | 07:57 AM
skinny z's Avatar
Re: 1LE brakes info need help for conversion
I can't answer your questions directly however having just completed a LS1 front brake conversion (and 1LE/PBR rears) I found these two web sites to be very helpful.
http://www.lukeskaff.com/
http://www.flynbye.com/
The Luke Skaff site has listings for many front upgrades with sizes and similarities arranged in a chart. You may find your answers there.
Old Sep 18, 2010 | 11:08 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
No, the parts aren't the same.
1LE service items are relatively uncommon and therefore more expensive. If I was going to do a brake upgrade again, I'd probably do the LS1 instead.
Old Sep 18, 2010 | 11:29 AM
92 BBC Z's Avatar
Car: Currently have 3 cars and 1 truck.
Engine: 1970&92 Cams,both BBC's
Transmission: LS1 T-56 & PG w/vendor's
Axle/Gears: Built 10 bolt& 9inch w/spool
When it comes to the vette brakes with that option,(the ones with the PBR caliper's are an option for car's with the H.D or Z-51 type suspention)the calipers are similar but the abatement bracket and spindle/rotor different. But don't think for one minute that EVERY part needed for a succesfull isn't available, because they are, easily. Like SkinnyZ said Flynbye, and other's have these parts in stock and ready to go.
Old Sep 18, 2010 | 06:31 PM
DiabloWS6's Avatar
thanks i will check out the websites
Old Sep 18, 2010 | 06:33 PM
DiabloWS6's Avatar
thanks for the opinion LS1 brake upgrade is a good upgrade but i whant to stick to the 1LE its more for the third gen and not every one has one but u can buy one but thanks for the commment
Old Sep 18, 2010 | 06:34 PM
DiabloWS6's Avatar
thanks for the help
Old Sep 21, 2010 | 06:30 PM
ebmiller88's Avatar
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
I have two full 1LE setups in the shop if you need one, LMK.
Ed
Vintageracer
Jan 10, 2020 05:33 PM
gta90
Sep 15, 2015 04:00 PM
lt1z350
Aug 28, 2015 05:57 AM
stalkier
Aug 21, 2015 01:54 AM
stalkier
Aug 13, 2015 12:59 PM
