ls1 front brake swap to 3rd gens
Car: 99 3000gt 88 gta vert 88 gta h/t
Engine: v6 /5.0 /5.7
Transmission: at/5 speed/at
Axle/Gears: ? /3.45/3.23
what modifications does it take to mount to 3rd gens besides the parts required thanks
Car: 91 formula ws6
Engine: 355 tpi OBDII
Transmission: 4l60E
Axle/Gears: 2.73 with 4th gen brakes
Re: ls1 front brake swap to 3rd gens
modified spindles, hubs, brakes themselves, longer wheel studs. not hard really. buying or making the brackets?
Car: 1992 Camaro ZO3
Engine: 350 HSR
Axle/Gears: 9 bolt/3.70's
Here is a good resource.
http://www.lukeskaff.com/car/brakes/faq.html
Car: 91 formula ws6
Transmission: 4l60E
that's the site i used in making my set up but then again i have the use of a machine shop at my disposal. lol. been on for 5 months now and i love it.
Car: 1989 Formula Firebird
Engine: Swapped 350 TPI speed density
Axle/Gears: 2.73 (soon to be 3.42)
what proportioning valve should i use? front ls1 rear stock 3rd gen drums for now
is there any adjustable options out there?
Car: 1986 Chevrolet Camaro IROC-Z28
Engine: TPI 310ci (LB9)
Transmission: Custom Rebuilt 700R4 - 2600 Stall
Axle/Gears: 10 bolt, 3.73 Eaton Limited-Slip
I use the stock prop valve and it works good.
Car: 89 IROC Z28
Engine: 357 TPI
Axle/Gears: 3.42 Posi
The 4th gen spindles won't work on these cars? Avoiding having to buy brackets and modifying the current spindles?
Car: 89 Iroc
Engine: 5.0L
Great website...but I am confused on what which to go with. will any of them fit on a 15" wheel.
what do people prefer..floating or fixed?
Car: 86 Camaro
Engine: 350 LT1
Those wont fit a 15" wheel, I believe a c4 setup will though. Spindle mod and hub is stupid easy if you are able to do it yourself. You can also take it to a machine shop and have them do it. Shouldnt be more than an hour or two in labor
Posted from Thirdgen.org App for Android
Car: 1989 camaro rs convertable
Engine: 305 tbi
Axle/Gears: 7.5"3.42 gears forth gen 2000 camar
some aftermarket wheels will clear lsi rear brakes.i swapped in a 2000 rear end and my 15" wheels barely clear.i still haven't added the front lsi brakes so im not sure about that.
sailtexas186548
Jan 19, 2016 12:21 PM
