Drum Brakes - Adjuster actuator lever loose
Car: 1989 Formula Firebird
Engine: Swapped 350 TPI speed density
Axle/Gears: 2.73 (soon to be 3.42)
I've done drum brakes many times before on other cars & trucks, but this 91 Camaro RS is the first one like this. Just an odd question: When assembled, is the adjuster actuator lever supposed to pivot freely and come off the top spring assembly (not the hold down spring)?
I can rotate the actuator back and forth so that it engages the top spring or comes unhooked. It doesn't look like it will ever miss catching the spring, but logically, it doesn't seem right.
Everything else appears to be in the correct position according to my repair manual and a photo of an assembled RS drum system, however, nothing mentions tension on the actuator.
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: Drum Brakes - Adjuster actuator lever loose
Does this diagram help you any? I mean I know you said you've done them before, but maybe you're missing a piece or something, and a peek at a diagram might help:
http://auto.howstuffworks.com/auto-p...rum-brake5.htm
Hate drums, so glad I swapped in a 4th gen rear with LS1 discs!
http://z28boy.cz28.com/pictures/rear%20brakes%201.jpg
It's the bent wire that connects the actuator to the pin and also the green spring.
Car: 87 IROC Z28
Engine: 355 cid TPI
Transmission: Custom Built 700R4 w/3,500 stall
Axle/Gears: QP fab 9" 3.70 Truetrac
How stuff works is not a complete or sometimes even accurate representation of how stuff works. Especially when it comes to vehicle systems. They show one type of auto adjusting drum brake when there are several different types. The 3rd gen doesn't use that design.
1991 RS, are you missing the small coil spring(lever return spring) that holds the actuator tight against the "bent wire" actuator link?
Car: 87 IROC Z28
Engine: 355 cid TPI
BTW, I learned long long ago never to tear down both sides of drum brakes at the same time. That way you have an example to go by should you get lost. That is as long as the last brake job was done correctly.
Yeah, I have done so many in the past I figured it was just routine. I learned my lesson here! Trending Topics
In the picture http://z28boy.cz28.com/pictures/rear%20brakes%201.jpg does the left hook on the white spring go to the left shoe or to the actuator?
Car: 1992 RS
Engine: Carbed 350
Not causing any issues with me. I mean, yeah the wheels do stick out a bit on each side, but it doesn't look bad to me, I like it. The ONLY time I have issues is when I'm loaded down with luggage, etc. - like when wife and I go to Carlisle or something and I've got a carload of stuff - but that's because I'm also lowered 1 inch. This year I'm installing airbags in the coil springs so that I can reduce the travel of the spring a bit. But until then, I just have to take it easy on bumps on the rare occasion that I'm loaded like that.
Sorry I'm not more help - it's been a lifetime ago since I had rear drums and I'm too senile to remember!
Car: 87 IROC Z28
Engine: 355 cid TPI
The white spring goes from shoe to shoe. The picture in your link is missing the small spring I referred to above. The spring goes ove the square stem you see extending from the actuator towrds the back of the rear(left) shoe. The spring applies pressure between the actuator and shoe. Without it the auto adjuster wont work.
I was thinking the same thing. I checked my springs that I replaced and it must have been missing there, too. The shoes were still quite full when we replaced them, probably due to no adjustment, but since we already had the parts and didn't know the quality of the old ones, we replaced them anyway.I'll have to get the springs and add them.
Car: 87 IROC Z28
Engine: 355 cid TPI
Yeah, that spring, along with the speader bar sprinc, is not included in the standard hardware kit. There is a parking brake, auto adjuster hardware kit available that includes those springs, the actuator and the adjuster.
Did finally get the brakes working correctly after adding the spring you mentioned (one on the square tab). Luckily, I know a mechanic who happened to have some that would work.
AkDrifted
Aug 17, 2015 07:45 PM
