confused about ebrake.. i need help plz
Car: 89 firebird bone stock for now
Engine: 2.8L V6
Axle/Gears: B.W 9Bolt 3.27 Posi
ok so im still a little confused about when switching from a drum to disk rear the appropriate ebrake or parking brake cable to use. i have an 89 firebird 2.8 with drums right now and i have a posi rear end with discs that i pulled off a what i believe was a 90 bird. i read in the sticky above that up to 88's that the cable was different from the 89's and above. what i want to know is if i buy two rear ebrake cables for left and right disc from my autoparts store (oreilly)would those cables be the same to the 90' one or should i search for a year 90' ebrake cables and not the 89's?? thanks
-Aaron
-Aaron
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: confused about ebrake.. i need help plz
JamesC
Engine: 2.8L V6
im not completely sure but i think they were aluminum
theres a difference in cable between alum and iron?
Engine: 2.8L V6
ok then i got to get them checked. ill ask my friend if he could take a look for me since i have the rear end at his place. when i find out can i just message you?
JamesC
Engine: 2.8L V6
ok cool. so if theres no little tunnel thingy. (is that like the one i saw in the sticky?) i should just get a 90 or older cable then? right?
Engine: 2.8L V6
alright soounds good. ill check when i get my baby back
thanks alot jamesc
thanks alot jamesc Thread
bubbaz28
Sep 18, 2015 02:09 PM
Denricci22
Sep 18, 2015 09:02 AM
Andrew Prakash
Sep 8, 2015 11:48 AM
