E-Brake Needs Adjustment.
Old Mar 24, 2011 | 12:40 PM
vistageek92's Avatar
Car: 1984 Camaro Z28 Clone
Engine: Bored .030, vortec sbc350
Transmission: Built T5 WC
Axle/Gears: 1999 Torsen 4:10 Locker
This has been bothering me for sometime now and has finally driven me up the wall to get this fixed...
Ever since I bought my camaro, the E-Brake took pulling all the way up until it was in the vertical position until it catched, and at that, barely. Now, it wont catch it all; not even pressing the rear brakes now...
So, figure I gotta tighten up the cable under the car.
Can someone kinda tell me how/where to do that on these Third gens?
Thanks in advanced guys
Old Mar 24, 2011 | 02:46 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: E-Brake Needs Adjustment.
Discs or drums?
JamesC
Old Mar 24, 2011 | 03:24 PM
Originally Posted by JamesC
Discs or drums?
JamesC
Whoops sorry! Forgot to mention that.
Drums. The car was originally a Sport Coupe
Old Mar 24, 2011 | 04:04 PM
JamesC's Avatar
Models With Rear Drum Brakes
1. Depress the parking brake lever exactly two ratchet clicks.
2. Raise the rear of the vehicle and support safely with jackstands.
3. Tighten the brake cable adjusting nut (seen in the pic below) until the left rear wheel can be turned rearward with both hands, but locks when forward rotation is attempted.
4. Release the parking brake lever, both rear wheels must turn freely in either direction without brake drag.
5. Lower the vehicle.
https://www.thirdgen.org/forums/atta...e-adjuster.jpg
JamesC
Old Mar 25, 2011 | 10:12 AM
ASE doc's Avatar
Car: 87 IROC Z28
Engine: 355 cid TPI
Transmission: Custom Built 700R4 w/3,500 stall
Axle/Gears: QP fab 9" 3.70 Truetrac
Before performing the adjustment as recommended by James C, be sure to verify proper adjustment of the rear brakes. It is common that the drum brakes are incorrectly assembled so that the auto adjusters don't function. This leads to excessive free play in the shoes and will cause the rear brakes as well as the e-brake not to function. The shoes should barely drag on the drums with no pedal pressure. After adjusting shoes, depress pedal to center shoes and recheck.
Old Feb 8, 2012 | 06:47 PM
cha_chard's Avatar
Car: 89 Camaro RS
Engine: 2.8L V6 MPFI
Transmission: 5Speed
how did you guys get to the nut on top, the drive shaft is in the way of getting my wrench....
Old Feb 8, 2012 | 06:59 PM
JamesC's Avatar
You can always remove the drive shaft--four bolts, IIRC.
JamesC
Old Feb 8, 2012 | 07:45 PM
I ended up having a shop do it, where they could put the car on a lift which drops the driveshaft when the car weight isn't on the ground. Either take the driveshft down or jack the rear of the car up off the suspension
Rocket-Doc
Nov 14, 2015 02:08 PM
Buickstaged
Brakes
Sep 4, 2015 07:53 AM
theshackle
Aug 31, 2015 10:47 AM
perZ
Aug 15, 2015 01:17 PM
Blown_n_Injected
Aug 23, 2001 03:48 PM
