Brake proportioning valve replacement??
Old Jul 2, 2011 | 07:59 PM
pbtrilogy's Avatar
Car: 1985 Z
Engine: 89 305 TPI
Transmission: 700-R4
Axle/Gears: OSD 10 bolt/ 3.42
Does anybody know of any place that sells a replacement for the brake proportioning valve?
I looked on advanced auto, autozone, oreilys, napa, pep boys, summit, ect...but couldnt find any replacement except for universal ones.
I replaced all my components for the front brakes trying to fix the passenger side from overheating and its still overheating so ive decided to replace the valve.
-Thanks
Old Jul 2, 2011 | 08:43 PM
lonesomeloser's Avatar
Car: 1983 Z28
Re: Brake proportioning valve replacement??
-Thanks
Carstuff.com, autopartswarehouse.com
Old Jul 2, 2011 | 08:54 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
I replaced all my components for the front brakes trying to fix the passenger side from overheating....
Does that include the flex hose?
JamesC
Old Jul 2, 2011 | 09:35 PM
Base91's Avatar
Car: Base 91 'bird
Engine: 3.1 v6
Transmission: 4L60
Axle/Gears: 9-bolt 3.27 & PBR
Before you replace the valve have you looked at other reasons one side may be overheating? Try swapping the front lines around to see if the overheating swaps sides or remains where it is. If it remains on the same side it's probably not the valve. May be a sticky piston or something.
Old Jul 2, 2011 | 09:43 PM
pbtrilogy's Avatar
Car: 1985 Z
Engine: 89 305 TPI
JamesC
nope, was thinking about that, but was told that if there is no bubble on the wall of the hose than it should be ok
Old Jul 2, 2011 | 09:46 PM
pbtrilogy's Avatar
Car: 1985 Z
Engine: 89 305 TPI
The first replacement calliper we put on there did have a sticky piston, but we changed that and tested the second replacement calliper on the car and it worked, but its still overheating.
Old Jul 3, 2011 | 06:21 AM
JamesC's Avatar
The problem would be internal. I doubt that you'd see any indication.
JamesC
Old Jul 3, 2011 | 07:09 AM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
stop taking advice from that person, moron.
they break down internaly, you will never see it. the very thin rubber linner comes lose and causes problems.
if you want till they look bad on the outside, no one would ever change them.
Old Jul 4, 2011 | 09:01 AM
FNFAL308's Avatar
Car: 91 Bird
Engine: TPI 350
Transmission: 5-Speed
Axle/Gears: 2.77 posi
I came on here just now still sweaty (sounds sexy huh?) from working on my brakes. I was going to man up for not believing it could be my brake hoses causing the front brakes to drag and over heat. HAH!
I changed every lower component BUT the hoses (because it was time). Rotors, new bearings, pads and calipers. When I went to drive it one was way too tight and the other a little too tight. I suspected EVERYTHING but the hoses. Read here on every post to CHANGE THE HOSES to stop this!!!! I said no way the hoses looks good and NO WAY could the hose hold the brakes closed since its so little fluid going back. Man I was wrong!!! (don't get used to me saying that ).
I changed the hoses and it worked immediately.
I've been working on cars for 30 years and maybe its because I change out things regularly, but I have NEVER had this problem. Could also be a design flaw.
Go change your hoses and be done with it. I am amazed that the rubber hose could cause that but it did. I'm telling you that the hoses on it did not look old and were not dry-rotted and were not collapsed or a funny shape and were not twisted.
Thanks third gen peoples
EDIT: Should be a banner at the top saying if you have not changed the hoses, don't post about sticking brake calipers. It is that important
Old Jul 5, 2011 | 09:47 AM
pbtrilogy's Avatar
Car: 1985 Z
Engine: 89 305 TPI
ok, well ill go change my hoses then and report back in the next couple of days
Old Jul 12, 2011 | 12:49 PM
55ChevyMan's Avatar
Car: 55 chevy Belair & 86IROC Z
Engine: 350 in 55 86IROC Z LT1
Transmission: 55 4speed IROC Z4L60e
Axle/Gears: 12 bolt 410 in55 and 342 inCamaro
I replaced front rotor pads and calipers and rear rotor and pads the problem is the right front I cant bleed it no fluid comes out and the pedal is hard the car had been park at least 10 years can I clean the system using denature alcahol would clean it I did this year a ago on my 55 chevy to clean and change to dot 5
Old Jul 12, 2011 | 04:11 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
http://viragotech.com/newtech/Brake%20Fluid%20Facts.htm
Old Jul 12, 2011 | 07:53 PM
55ChevyMan's Avatar
Originally Posted by 55ChevyMan
I replaced front rotor pads and calipers and rear rotor and pads the problem is the right front I cant bleed it no fluid comes out and the pedal is hard the car had been park at least 10 years can I clean the system using denature alcahol would clean it I did this years a ago on my 55 chevy to clean and change to dot 5
the problem was an old clogged hose changing to stainless steel hose's in front and back and on my 55 chevy I been using dot 5 since 1982 no problems
Old Nov 7, 2011 | 08:29 AM
streetpro's Avatar
Car: 1987
Engine: 454
Hi james im having trouble getting the front brakes to work,put on new brake booster,master cylinder,lines,hoses,roters,drums,pads,shoes.
the rear brakes only ones working.no air coming out of lines just fluid.
any ideas.i may try rebleeding again,im mad at it have not got the big hammer out yet.
Old Nov 7, 2011 | 09:41 AM
JamesC's Avatar
Did you bench bleed the new master?
JamesC
Old Nov 7, 2011 | 09:56 AM
streetpro's Avatar
Car: 1987
Engine: 454
yes
Old Nov 7, 2011 | 09:59 AM
JamesC's Avatar
Humm, well, some members have been forced to bleed multiple times, so....
JamesC
Old Nov 7, 2011 | 10:04 AM
streetpro's Avatar
Car: 1987
Engine: 454
james im going to bleed them again, mabey the valve is out of position
everything is new on the brake system,no leaks,well im going in,thanks for your help.
Old Nov 8, 2011 | 06:55 PM
streetpro's Avatar
Car: 1987
Engine: 454
James you were right just one more time fixed her right up,also master cylinder was redone they are perfect now.Again thanks james.
gta90
Sep 15, 2015 04:00 PM
Zachattack0925
Aug 12, 2015 09:52 PM
MustangEater82
Brakes
Aug 11, 2015 07:52 AM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
