Drum to disc swap - poor performance - proportining valve?
Old Sep 8, 2011 | 01:50 PM
RMK's Avatar
RMK
Car: 87 IROC
Engine: modded LB9
Transmission: Pro Built 700R4
Hi,
I've swapped my rear drums in my 87 IROC over to Ed's 12" disc setup and am experiencing dire, almost non existent, performance from the brakes. I'm wondering if this is down to the proportioning valve still being for the drums? From speaking to Ed I wasn't sure if I needed to swap it over as when ordering the kit he said if he had one he would include it although I probably wouldn't need it.
I've attached a picture of the part I have. The numbers on it read:
NB 14 KH 1479
and
0025 26751
The handbrake is also pathetic but at this stage I need to get the fot brakes working as a main priority to get it through UK safety testing.
Thanks,
Attached Thumbnails Drum to disc swap - poor performance - proportining valve?-dsc_0384.jpg   Drum to disc swap - poor performance - proportining valve?-dsc_0385.jpg
Old Sep 8, 2011 | 07:56 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: Drum to disc swap - poor performance - proportining valve?
I'd say it's more of a bleeding problem. As I've read, the drum prop valve actually sends too much pressure to disc brakes - folks swap them out so that the rears don't lock too quickly. Start at pass rear, then do driver rear, then pass front, then driver front. Bleed until it hurts, then bleed some more.
Old Sep 9, 2011 | 09:03 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Though the drum valve will work (or should), for the best brake performance, using the valve with the correct bias is the best bet. There are valves for disc/drum, standard disc/disc and 1LE disc/disc.
JamesC
Old Sep 9, 2011 | 10:42 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Problem with the rear drum prop is its designed to hold a bit of brake PSI in the line so they work quicker. Which should have them draggin a little bit???
[Been down a road of bad brakes for a few years now, all new parts n gallons of fluid changes all new but hard line hasn't changed a thing. Like standing on a rock.]
Old Sep 11, 2011 | 12:09 PM
RMK's Avatar
RMK
Car: 87 IROC
Engine: modded LB9
Can anyone confirm if that is the correct prop valve? I'm going to swap it out and check the master cylinder at the same time to see if there is anything untowards in there.
Gumby,
Do your brakes work and it's just that they have a hard pedal or are they completley crap?
Old Sep 11, 2011 | 12:49 PM
thomas1976's Avatar
Car: 91 Trans am
Engine: built 360 TBI
Transmission: built 700r4
Axle/Gears: 10bolt/3.23
I have the drum disc conversion kit from hawks (not installed yet).
The calippers are not identical, one calipper is missing the return springs, one caliper cable bracket L is platet the R not, rotors are expensive bear's 12" (useless over here), no hard lines.
This should already cheer you up.
I asked and payd for a 1LE prop valve too. They sent me a 91-92 ILE valve with # MB 9 KH 2171 on it.
I really hope it is a 1LE combination valve.
From experience I know the disc hand brake is ridicoulous compared to the drum hand brake.
Old Sep 11, 2011 | 02:09 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Gumby,
rock auto list a disc disc on their site.
My brakes are like manual brakes, gotta lean on it hard to stop. If it wasnt a stick id be in big trouble. But panic stops still suck like scooty puff jr. Even more so since my right leg is about half strength still being down for a few month with some wild never pain. So its no pleasure to have to lean on it at times.
Old Sep 11, 2011 | 04:38 PM
JamesC's Avatar
First-design 1LE.
JamesC
Orr89RocZ
Apr 25, 2016 08:28 AM
gta90
Sep 15, 2015 04:00 PM
SpaniardV6
Brakes
19
Sep 7, 2015 03:04 AM
NBrehm
Aug 25, 2015 11:49 PM
THABADGUY
Brakes
Aug 11, 2015 03:43 AM
