brake problems
Old Jan 22, 2012 | 02:54 PM
killerdove's Avatar
Car: 1986 Camaro z28
Engine: 350 5.7
Transmission: t5
brake problems
alright so my problem is when I hit my brakes the pedal goes straight to the floor. I have replaced the m/c twice, put new calipers and wheel cylinders and bled the system repeatedly. Any ideas? Thanks
Old Jan 22, 2012 | 04:21 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: brake problems
if it goes right to the floor, and thats it, thats an issue with the booster, or possibly the linkage to the pedal.
Old Jan 22, 2012 | 05:41 PM
spotspot's Avatar
Car: 90 RS Camaro
Axle/Gears: stock
Re: brake problems
if you pump the brakes do they build pressure, if so check for leaks in the system if not check for trapped air
Old Jan 22, 2012 | 05:59 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Re: brake problems
did you bench bleed the master cylinders?
Old Jan 22, 2012 | 09:27 PM
killerdove's Avatar
Engine: 350 5.7
Transmission: t5
Re: brake problems
so when I pump breaks it always they same feel, can't be booster cause pedal still moves and master cylinder gurgles when breaks press(cap is on). M/c has been bench bled and so has the hole system
Old Jan 22, 2012 | 09:44 PM
spotspot's Avatar
Car: 90 RS Camaro
Axle/Gears: stock
Re: brake problems
if the m/c is gurgling then there is air in the system try bleeding it again good luck some times it can be a pain when everything is new
Old Jan 22, 2012 | 09:53 PM
killerdove's Avatar
Engine: 350 5.7
Transmission: t5
Re: brake problems
thanks I appreciate it. I'll try again tomorrow, I'll let you know
Old Jan 22, 2012 | 10:03 PM
spotspot's Avatar
Car: 90 RS Camaro
Axle/Gears: stock
Re: brake problems
you can take the caliper and fill it with brake fluid it might help good luck to you
Old Jan 23, 2012 | 09:46 PM
killerdove's Avatar
Engine: 350 5.7
Transmission: t5
Re: brake problems
alright so today me and my step dad figured it out. One of my parking brake cables isn't working so we adjusted the drums and now I have pressure back in my pedal. But now I need to replace parking brake cables and I'm going to bleed it one more time to be sure
ZMWojnar
Brakes
May 12, 2019 10:43 PM
SpaniardV6
Brakes
19
Sep 7, 2015 03:04 AM
overdriv
Aug 20, 2015 03:52 PM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
