coarse thread bleeders
Old Mar 19, 2012 | 01:25 AM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
are they putting coarse thread bleeders in re-man calipers with out thinking???
even just lose a tiny bit they will suck air around the threads, I watched bubbles drain out for about 5 mins before I caught onto it and covered the exposed screw portion with some anti-sieze and walla, no more air in the hose aka the line n caliper was bleed.
IM sure these things use to be fine thread on purpose just for that reason.
Old Mar 19, 2012 | 05:26 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: coarse thread bleeders
Bleeders do not seal with the threads, so it does not matter if they are fine or coarse. Sound like.something else is wrong.
Old Mar 19, 2012 | 05:28 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Air won't get in past the threads unless you're doing it wrong or using a vacuum bleeder.
Elephantismo
Feb 13, 2019 12:51 AM
armybyrd
Oct 24, 2015 06:59 AM
355tpipickup
Sep 28, 2015 05:50 PM
Linson
Sep 21, 2015 01:08 PM
84redta
Sep 19, 2015 09:58 AM
