wierd nut size on rear brake lines
Old Apr 15, 2012 | 05:31 PM
my86bird's Avatar
Car: 1986 Firebird
Engine: 2.8L
Axle/Gears: As far as I know
R u guys ready for this? I'm finally ready to get my 86 bird (2.8L v-6) back on the road, so I tried to bleed the brakes (disc front, drum rear), starting with the right rear like the Firebird Shop Manual suggests. Since i wasn't having luck with the vacuum one-man bleeder kit I bought, I got in and pumped the brake pedal a few times to get the fluid started. The brake line on the left rear side (mounted on the axle) blew open. I tried to take the line off but, are you guyz ready, an 11mm fitting wrench, aka flare nut wrench, doesn't fit and a 12mm open end is too big! 7/16" is too small and 1/2" is too big. How the heck can I get this thing off? Anyone got any ideas? Anyone have this problem? Anyone know what the real size of these *#@!&* nuts are supposed to be? PLEEEEZ HELP!!! Anyone?
Old Apr 15, 2012 | 05:36 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: wierd nut size on rear brake lines
its metric, and rust build up may have made its a little larger. clean it up, sand it if you have too and you should be able to get the 11mm wrench on.
Old Apr 16, 2012 | 12:00 AM
Sojer's Avatar
Car: 1987 IROC-Z red t-top
Engine: Nothing much
Transmission: I wish t56
Axle/Gears: 9bolt 3.27 4sale
Vise grips
Old Apr 17, 2012 | 04:58 PM
my86bird's Avatar
Car: 1986 Firebird
Engine: 2.8L
Thanx for the advice. I have a friend of a friend who is an an ex professional ( his company decide it was time for him to retire ) coming by tomorrow and I'll suggest that to him. Sounds logical, hopefully it'll work.
Old Apr 17, 2012 | 07:19 PM
Sojer's Avatar
Well I am a pro if its stuck use heat its not that big so u don't have to get it red
Old Apr 18, 2012 | 10:35 AM
my86bird's Avatar
Car: 1986 Firebird
Engine: 2.8L
More good advice. The guy will B here soon so I'll get my little torch out in case he wants 2 use it. Can't wait to get 'er back on the road.
I love this site. So much great advice from all over the country on so many problems that we faced with our beloved 3rd gens. I personally can't thank you people enuff.
Reddeath210
Oct 6, 2015 08:20 AM
kyleb24
Aug 15, 2015 08:24 AM
Leggman1
Brakes
Aug 12, 2015 08:39 PM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
Leggman1
Aug 6, 2015 04:15 AM
