Rear brake pads for iron calipers? 87 GTA
Old Jul 28, 2012 | 09:15 PM
hydrolic144's Avatar
Car: 1987 GTA Trans Am
Axle/Gears: Borg Warner 9-Bolt 3.27
87 GTA with the 9-bolt disc rear end. My brakes actually do work, and extremely well, but they are just many years old and I'm looking for replacements. I read on here that the fronts will also work on the rear, but that didn't work.
Anyone have any suggestions on a good set of pads?
Old Jul 29, 2012 | 01:31 PM
87zjeff's Avatar
Axle/Gears: '01 3.42 10 bolt
Re: Rear brake pads for iron calipers? 87 GTA
my 87 iroc had the 9 bolt disc rear and the front pads were the same as the rear. only difference being i had to pry the clip off the pad that was used to hold it into the front caliper piston to use it on the rear solid caliper piston if the clip was already on the pad.
Old Jul 29, 2012 | 06:16 PM
How did you get the rear caliper piston back in? I tried the c-clamp method but seemed it wasn't moving it at all.
Old Jul 30, 2012 | 06:41 AM
87zjeff's Avatar
the rear caliper piston is threads into the caliper. it requires use of the e-brake to keep it adjusted. there is a tool you can get from most auto parts stores to use for threading it back in.
Old Jul 30, 2012 | 08:29 AM
hrspwr's Avatar
Car: 86 IROC
Engine: 350 Vortec TPI
Axle/Gears: BW 3.27
+1. Did the same on mine. The piston does not compress in, you actually have to spin/thread it back into the caliper. Be careful not to rip the dust boot.
Old Jul 30, 2012 | 11:15 AM
ILMODC's Avatar
Wait, could I have damaged mine? I used a huge C clamp and i got em in a touch to slide back on.
Reason why I ask, is I broke the factory seal and now have a leak where the hose connnects to the bottome of the caliper. I keep hearing to use a crush washer and it will cure the leak. Now I'm wondering if I jacked up the caliper and its actually leaking at the piston and not the bolt as it appears?
So you are saying when you press the brake, the piston actually spins out instead of pushing out?
Old Jul 30, 2012 | 11:28 AM
Wow! Did not know that. Good thing I didn't force it but I did notice that I had to spin it to line it back up with the old brake pad notch. The clips that hold the brake pad to the caliper, should I replace those?
Old Jul 30, 2012 | 01:14 PM
hrspwr's Avatar
Car: 86 IROC
Axle/Gears: BW 3.27
Inside the caliper there is a mechanism that self adjusts the caliper everytime the piston is moved out OR when the ebrake is applied. To get the piston back in, it has to be spun not pressed. I found it out the hard way as well. I tried to press the caliper in as well like any other caliper that I have seen, but it would not go. Out of curiosity, by hand, I spun the ebrake weight to apply the ebrake and saw the piston spin. I got out the chanel locks and spun the piston the opposite way and sure enough it went back in. But my problem was that the chanel locks grabbed the dust cover/boot and ripped it, so make sure you are careful when you do this. this is also why you had to spin it to line up the 'brake pad notch', it spun at one time....
Spin it, line it up put it on and your golden. If the clips are brittle and need to be replaced then yes. If they are in good shape, leave them.
You may be ok, but it depends on where the leak is....The copper crush washers(plural) should be used when tightening the line to the caliper. This will make sure that any imperfection(s) in the flex line and the caliper are corrected with the washer (same thing applies where any gasket is used...). You cannot reuse them either as they will leak if you do. Try that first IF you do not have them on the caliper now. When putting the line on it should go banjo bolt, crush washer, flex line, crush washer then caliper. The crush washers should be sandwiching the flex line. Like this (compliments of carcraft lol)
Old Jul 31, 2012 | 04:15 AM
TreeFiddy's Avatar
Car: '86 TA
Engine: '74 350
Axle/Gears: 2.77
Yeah, don't use a c-clamp, you can damage the internal screw/bolt. I had never heard of this piston spinning thing either, until I did mine last year. Use this tool to make life easy:
http://www.summitracing.com/parts/OTC-4589/
I did not know this tool existed either at the time, so I made this:
Here is the internals of my caliper, note this is the recall-kit pistons. You can see that of you use a c-clamp to try retracting the piston, you are actually trying to crush it down the thread rather than spinning as is required.
Old Jul 31, 2012 | 04:32 AM
brando54009's Avatar
Car: 82 firebird
Engine: a few
Transmission: th350
Axle/Gears: wondering this myself
cant you just use one of those zinc coated brake caliper blocks from the parts store for like 5 bucks and push in while you turn it? thats how I've done most rear brake setups
Old Jul 31, 2012 | 05:00 AM
TreeFiddy's Avatar
Car: '86 TA
Engine: '74 350
Axle/Gears: 2.77
Yep, linked to one above for about $10.
I made my little doohickey. Then went to the local parts shop and saw them hanging on a hook. Then I went
Old Aug 1, 2012 | 09:15 PM
Awesome!! Saw that tool at AutoZone for $12. Great info!
Question though. When you turn the piston in, and line everything up. When it's time for the piston to compress again, and how it spins, how does it turn and keep the brake pad in place?
Old Aug 2, 2012 | 07:56 AM
hrspwr's Avatar
Car: 86 IROC
Axle/Gears: BW 3.27
When the brakes are depressed or the ebrake is pulled, the piston does not spin, it comes straight out. It is on a ratcheting mechanism that allows it to stay as you positioned it. This allows it to also keep the pad in place.
To compress the piston, it must be spun.
Old Aug 2, 2012 | 12:42 PM
TreeFiddy's Avatar
Car: '86 TA
Engine: '74 350
Axle/Gears: 2.77
Moreso, the piston MUST NOT spin during normal brake operation, or the piston ratchet wear adjuster and handbrake screw actuator won't work properly.
The little nubbin on the pad that interlocks with the slot in the head of the piston, is essential to keep the piston from spinning, and keep the pad in place. Before I figured it all out, I managed to get the piston retracted, but the slot was mis-aligned. I nearly ground the nub off the pad myself just to get it in and be done with it.
Luckily (ironically) I managed to damage the piston seal in my initial ham-fisted piston retraction with locking pliers (painfully slow), which led to fully dismantling the caliper to replace it (tearing out hair). Upon appreciation of how the thing actually worked, it became apparent what a mistake grinding that off would have been.
Old Jul 7, 2013 | 09:57 AM
batty113's Avatar
Car: 1988 Firebird GTA
Engine: 5.7
Axle/Gears: 3.23 posi
Does anyone know where to get new brake pad clips for the rear brakes? I tried the parts stores and they don't know what I'm talking about.
Vintageracer
Jan 10, 2020 05:33 PM
Eric-86sc
Apr 3, 2016 03:52 PM
sailtexas186548
Jan 19, 2016 12:21 PM
kyleb24
Aug 15, 2015 08:24 AM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
