Bracket for larger rear rotors
Old Dec 5, 2012 | 08:32 PM
92RS(real slow)'s Avatar
Car: 92 RS(sold) 1989 IROC-Z
Axle/Gears: ones that turn
Does anyone else other than ed miller make caliper brackets to run larger rotors on 10-bolt with pbr's? After upgrading my fronts to c4hd brakes I want a larger rear rotor to balance out the look, and the extra surface area couldn't hurt with stopping as well.
Old Dec 6, 2012 | 07:11 PM
87350IROC's Avatar
Car: 87' IROC
Re: Bracket for larger rear rotors
I don't know if anyone else is currently making brackets for that application.
I'm not sure what rotor Ed uses, but typically the rear brackets are quite easy to design for those calipers since the e-brake is built in.
What size rotor were you thinking about?
Old Dec 6, 2012 | 07:27 PM
Id like to run 13" if possible, but i would be okay with 12's
Old Dec 8, 2012 | 12:26 PM
91 1LE's Avatar
Car: '91 1LE
Engine: 377 w/Stealthram
Axle/Gears: 3.42 Torsen
Baer Brakes makes brackets for at least 13" rotors. Some of their kits use the PBR caliper in the rear but you would have to call to see if they will sell them separate. They have them for both 9 and 10 bolt rears.
Old Dec 8, 2012 | 12:37 PM
87350IROC's Avatar
Car: 87' IROC
Yup. The bracket is no problem. The big question is what 13"x0.8" rotor are they using? I have found no such beast in my searching.
Old Dec 8, 2012 | 12:43 PM
Twin_Turbo's Avatar
Their own custom rotor. One guy here has them, I have seen his pics here. It's a 2 pc rotor. eradispeed+
Old Dec 8, 2012 | 01:16 PM
87350IROC's Avatar
Car: 87' IROC
I'm not sure. Somebody has mentioned to me in the past that FlynBye offers a 13" rotor for the PBR rear brakes. I have not confirmed this myself. I would assume that would be a 1pc rotor.
Old Dec 8, 2012 | 02:11 PM
I'll have to do some research on the baer stuff, and see what parts are available. I really would prefer to keep everything stock gm parts if possible. I want everything to look stock. That's why I would really like to stick with pbr's.
Old Dec 8, 2012 | 09:31 PM
Twin_Turbo's Avatar
It was Ed
https://www.thirdgen.org/forums/engi...s-13-baer.html
Old Dec 10, 2012 | 09:24 PM
91 1LE's Avatar
Car: '91 1LE
That's what I have. 13" 2 pc Baer rotor with a PBR caliper.
Old Dec 10, 2012 | 09:34 PM
Do you happen to have a part number for the rotor? I would rather no buy from ed unless I have to. My last transaction with him did not go well at all.
Old Dec 10, 2012 | 11:48 PM
91 1LE's Avatar
Car: '91 1LE
I don't have the part numbers as they were part of a complete kit. If you call Baer Brakes they should be able to get you what you need. They are easy to deal with.
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
ZMWojnar
Brakes
May 12, 2019 10:43 PM
Eric-86sc
Apr 3, 2016 03:52 PM
