prop vale ? help?
Old Feb 21, 2014 | 07:20 PM
Claybraham's Avatar
Car: 91 rs camaro hard top
Engine: 350 vortec
Transmission: 5 speed. T5
Axle/Gears: 3.70 gear 9 bolt posi. disc brakes
prop vale ? help?
i know this has been gone over and over again, but here goes one more. i just want to verify that im right before jumping in.
;i have a 91 that had drums. i swapped out with a 87 9 bolt rear end with disc brakes. it has iron calipers. i have no rear brakes, due to the fact that my stock valve is set up for drums. so i want to replace my stock valve with a adjustable proportioning valve. the set up im looking to due is like this...
question is will this prop valve work for me? (link below)
http://www.jegs.com/i/JEGS-Performan...ductId=2157608
says do not use with metric or abs, does that really matter for my application?
if not, does anyone know what would be the best adjustable valve for me?
yes ive searched threads and what not for a few days now.... i cant seem to find anything. im sure i might be bashed on a little for this but any help is much appreciated! thanks in advance!!!!!!
Old Feb 22, 2014 | 08:35 PM
Claybraham's Avatar
Engine: 350 vortec
Re: prop vale ? help?
just ordered it, guess ill find out. from what i know the rear brake line is 6mm (close to 1/4).
Old Feb 23, 2014 | 02:49 PM
83L69Camaro's Avatar
Car: 83 L69 Z28 T tops
Engine: 305 H.O.
Transmission: 5 spd
Axle/Gears: 3:73
ClayBraham, Cgeck this thread out. I'm working on the same issue with my Z and this is what I found. https://www.thirdgen.org/forums/brak...e-upgrade.html
I bought a Prop valve from Summit and it work ok then wouldn't work the rears again so I'm going to try the spring change next.
Old Feb 23, 2014 | 05:42 PM
Claybraham's Avatar
Engine: 350 vortec
This was really helpful! Thank you so much! I didn't even see this thread while searching. I guess I read so much I looked over this. Thank you! I just may give this a try first, I orders the prop valve last night and its in back order... Thanks again! Please keep me posted if this works for you
Old Feb 25, 2014 | 03:27 PM
Claybraham's Avatar
Engine: 350 vortec
I orderd the spring from grainger, it works I noticed a big difference! My back brakes actually lock up now. I don't think it's exactly where it should be though. 10x better than before so I'm happy! Thanks agian!
Old Apr 2, 2014 | 07:20 PM
BadRiggins's Avatar
Car: 1989 Pontiac Firebird Trans Am
Engine: 5.0 305 V8 FI
Transmission: 700R4 Automatic
Can anybody help me? I cross threaded my proportional valve and need to get a new one. I finally found one that looks like it would be the right one.
http://www.hawksthirdgenparts.com/pr...-Calipers.html
It says that it has to have aluminum calipers, but I don't understand why it would matter when it goes through the brake lines to my calipers...
Any help?
Old Apr 2, 2014 | 08:39 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Originally Posted by BadRiggins
It says that it has to have aluminum calipers, but I don't understand why it would matter when it goes through the brake lines to my calipers... Any help?
For best brake performance use the combination valve designed for your application.
Disc/drum (82-89)
Disc/standard disc (iron Delco-Moraine calipers) (82-88)
Disc/so-called 1LE disc (PBR alum calipers) (89-92)
JamesC
Old Apr 2, 2014 | 08:44 PM
BadRiggins's Avatar
That's the problem, I have the 2nd design one and it's discontinued. I can't seem to find one, and this one looks exactly right. I don't know what I can do to get my car back on the road.
Old Apr 3, 2014 | 06:42 AM
JamesC's Avatar
...and this one looks exactly right.
You can't tell by looking. It's advertised as 90-92, which would be the second design years. Perhaps a call to Hawks is in order.
JamesC
manualbrakes.com
Brakes
63
Apr 9, 2024 11:55 AM
antman89iroc
36
Jan 31, 2016 08:42 AM
corey8084
Sep 17, 2015 02:56 PM
IROCThe5.7L
Sep 17, 2015 07:48 AM
Necron
Brakes
Sep 14, 2015 12:45 PM
