Timken Front wheel bearing selection
Old Apr 2, 2014 | 09:39 PM
whatdayasay's Avatar
I have a 90 RS with a 3.1 EFI
The parts store sold me set 3 & set 6.
Set 3 is for the outer bearing with a 1LE brake option.
I think the outer bearing should be a set 34 which is for a non 1LE brake option.
I don't even know what a 1LE brake option is & I haven't test the bearing in the rotor for fit.
Old Apr 3, 2014 | 08:09 PM
plum92_camaro's Avatar
Car: 92 Camaro RS
Axle/Gears: 10bolt w3.42 Torsen
Re: Timken Front wheel bearing selection
1LE is a rare performance option with larger brakes. You would have 1LE in your RPO codes sheet if you had it. I had trouble with the store not being able to tell which bearings were for 1LE and non 1LE. Here is a link to my thread. https://www.thirdgen.org/forums/susp...out-wheel.html
Old Apr 3, 2014 | 09:09 PM
Thanks!
dyeager535
Aug 28, 2015 08:10 AM
kah992
Aug 19, 2015 02:55 PM
wruiz
Aug 11, 2015 02:59 PM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
